Found 2Mbit BIOS (6.x)!
Attention! - found Gigabyte-BIOS!
Found AMD K7-BIOS/platform!
1. New CPU Support           :Can`t find "Unknow"-string for AMD!
1a.Bus Disconnect Support    : -> fixed.
2. XP frequency              :Can`t found frequency_st!
3. New Koeffs Support        : is not needed to be fixed.
4. 32Gb-problem              : not found.
5. Some HDD detect-problem   : not found.
6. "MB"/"GB" string search   : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x  : not found.
11.New Stepping Support      : WaCBROM V2.07 (C)Award Software 2000 All Rights R
eserved.
Adding modul.tmp  32.2%
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding start.tmp  87.5%
(c)2002-2003 apple_rom, www.ROM.by
Патчер пока не поддерживает K8. Поддержка оных вкупе с прескотинками - скоро будет.
