BIOS Patcher ver. 4.23.
Found 1Mbit BIOS!
1. New CPU Support : -> fixed.
2. P3-detect error : is not needed to be fixed.
3. New Koeffs Support : -> fixed.
4. 32Gb-problem : -> fixed.
5. Some HDD detect-problem : -> fixed.
6. "MB"/"GB" string search : -> fixed.
7. 65Gb-problem (1-st step) : -> fixed.
8. 65Gb-problem (2-nd step) : -> fixed.
9. Error display Freq>999MHz : is not needed to be fixed.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: -> fixed.
Write Allocate addinng: not found.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 30.5%
Adding start.tmp 87.5%
(c)2002-2003 apple_rom, www.ROM.by
и для пущей уверенности:
>cbrom TU0727.BIN /D
******** TU0727.BIN BIOS component ********
No. Item-Name Original-Size Compressed-Size Original-File-Name
0. System BIOS 20000h(128.00K) 1169Eh(69.65K) original.tmp
1. XGROUP CODE 03BD0h(14.95K) 02A73h(10.61K) awardext.rom
3. PCI driver[A] 06800h(26.00K) 06593h(25.39K) 8205u.bin
4. Other(4E00:0000) 00E6Eh(3.61K) 0048Dh(1.14K) modul.tmp
5. Other(2E55:0005) 00020h(0.03K) 00041h(0.06K) start.tmp
Total compress code space = 1B000h(108.00K)
Total compressed code size = 1AEB7h(107.68K)
Remain compress code space = 00149h(0.32K)
** Micro Code Information **
Update ID CPUID | Update ID CPUID | Update ID CPUID | Update ID CPUID
Напоминаю, что оригинальную прошивку можно слить отсюда: tu0727.exe
Ухххх. Кажется я проблему решил
БИОС для сказюка пока что лежит здесь. Откликается на 8205u....
Теперь логи:
CBROM V2.07 (C)Award Software 2000 All Rights Reserved. ******** TU0727.BIN BIOS component ******** No. Item-Name Original-Size Compressed-Size Original-File-Name ================================================================================ 0. System BIOS 20000h(128.00K) 1169Eh(69.65K) original.tmp 1. XGROUP CODE 03BD0h(14.95K) 02A73h(10.61K) awardext.rom 2. PCI driver[A] 06C8Ah(27.13K) 06B54h(26.83K) 7880v126.27k 3. EPA pattern 02D3Ch(11.31K) 00345h(0.82K) iwillbmp.bmp Total compress code space = 1B000h(108.00K) Total compressed code size = 1AFAAh(107.92K) Remain compress code space = 00056h(0.08K) ** Micro Code Information ** Update ID CPUID | Update ID CPUID | Update ID CPUID | Update ID CPUID ------------------+--------------------+--------------------+-------------------Затем делаем
и <...барабанная дробь...>
лог патчера:
>cbrom TU0727.BIN /D CBROM V2.07 (C)Award Software 2000 All Rights Reserved. ******** TU0727.BIN BIOS component ******** No. Item-Name Original-Size Compressed-Size Original-File-Name ================================================================================ 0. System BIOS 20000h(128.00K) 1169Eh(69.65K) original.tmp 1. XGROUP CODE 03BD0h(14.95K) 02A73h(10.61K) awardext.rom 2. EPA pattern 02D3Ch(11.31K) 00345h(0.82K) iwillbmp.bmp 3. PCI driver[A] 06800h(26.00K) 06593h(25.39K) 8205u.bin 4. Other(4E00:0000) 00E6Eh(3.61K) 0048Dh(1.14K) modul.tmp 5. Other(2E55:0005) 00020h(0.03K) 00041h(0.06K) start.tmp Total compress code space = 1B000h(108.00K) Total compressed code size = 1AEB7h(107.68K) Remain compress code space = 00149h(0.32K) ** Micro Code Information ** Update ID CPUID | Update ID CPUID | Update ID CPUID | Update ID CPUID ------------------+--------------------+--------------------+-------------------Напоминаю, что оригинальную прошивку можно слить отсюда: tu0727.exe
