BIOS Patcher ver. 6.00.alpha_15. |for Award/Phoenix & AMI bioses|
Found 2Mbit Award BIOS (6.x)!
Attention! - ASUS BIOS!
Found Pentium4-BIOS/platform!
1. New CPU Support : not found.
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : found, but more than one result!
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: not found.
Tweak options addinng:
MODUL.TMP
error!
0002>File not found
(c)2002-2004 apple_rom, www.ROM.by
(c)2006 Angel07, www.cgi-scripts.info
Вот что все время биос патчер выдает:
MODUL.TMP
error!
0002>File not found
