Как и чем удалять? и чего это у меня
Как и чем удалять?
и чего это у меня так много not found?
MB: p4g8x
BIOS Patcher ver. 4.23.
Found 4Mbit BIOS!
1. New CPU Support : not found.
2. P3-detect error : not found.
3. New Koeffs Support : not found.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : not found.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : Warning! Not found "genu"!
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: not found.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.08 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 13.4%
1003.bin have not enough space for adding ROM. (Over 5E1Fh bytes)
Adding start.tmp 87.5%
Adding cpucode.bin .... 55.9%
(c)2002-2003 apple_rom, www.ROM.by
Проблема: not enough space for adding ROM.
