А если
PCI IRQ CONFIGURATION (PCI SLOT 2 ONLY) Setting JP39 INTA#2 pins 1 & 2 closed IRQ14 (edge trigger) pins 3 & 4 closed IRQ15 (edge trigger) pins 5 & 6 closed
В 1-2 и контроллер во второй PCI? Остальные в pins 2 & 3 closed, допустим.
А если
PCI IRQ CONFIGURATION (PCI SLOT 2 ONLY) Setting JP39 INTA#2 pins 1 & 2 closed IRQ14 (edge trigger) pins 3 & 4 closed IRQ15 (edge trigger) pins 5 & 6 closedВ 1-2 и контроллер во второй PCI? Остальные в pins 2 & 3 closed, допустим.
