BIOS Patcher ver. 4.23. Attention! Advanced qualification is required! Found
Found 2Mbit BIOS (4.5x)!
1. New CPU Support : -> fixed.
2. P3-detect error : is not needed to be fixed.
3. New Koeffs Support :> -> fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : found, but Unknown format!
Add new freq in BIOS Setup: 105/35 MHz 110/36 MHz 115/38 MHz 120/40 MHz
14.Set "Y" as default on exit: -> fixed.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 27.9%
Adding start.tmp 87.5%
Adding cpucode.bin 55.9%
Еще замечание: старый биос (самая первая версия и без патча) тоже заводился и работало все точно также. Только что CPU ID был кривой и частота неверно отображалась 706(733).
