The actual total size of the disk is read using the READ NATIVE MAX ADDRESS command. This "soft disk size" is set using the SET MAX ADDRESS command. It comes in two flavours: if the "volatile" bit is set, the command will have effect until the next reboot or hardware reset; otherwise the effect is permanent.
