это у rgt :
это у rgt:
Hot CPU Tester Pro 4.0.0.578 - Benchmark Result
Thursday, December 16, 2004 - 01:42
Overall : 4023
MetaBench to MHz ratio : 2.68
Integer Instructions : 343 M Instructions/s
Floating-point Instructions : 488 M Instructions/s
MMX Instructions : 678 M Instructions/s
SSE Instructions : 257 M Instructions/s
SSE2 Instructions : N/A M Instructions/s
3DNow! Instructions : N/A M Instructions/s
Memory fillrate memcpy method : 468 MB/s
Memory fillrate C++ method : 446 MB/s
Memory rep movsd : 461 MB/s
Memory FPU 8 bytes blocks : 446 MB/s
Memory Assembly 4 bytes blocks : 444 MB/s
Memory Assembly 8 bytes blocks : 450 MB/s
Memory fillrate MMX 8 bytes blocks : 454 MB/s
Memory fillrate MMX 16 bytes blocks : 448 MB/s
Memory fillrate SSE 16 bytes blocks : 451 MB/s
Memory fillrate SSE movntq 8 bytes blocks : 469 MB/s
Memory fillrate SSE movntq 16 bytes blocks : 474 MB/s
Memory fillrate SSE prefetch movntq 16 bytes blocks : 473 MB/s
Memory fillrate SSE movntps 16 bytes blocks : 482 MB/s
Memory fillrate SSE prefetch movntps 32 bytes blocks : 481 MB/s
Memory fillrate SSE2 prefetch movntps 16 bytes blocks : N/A MB/s
Insertion Sort : 29 K Items/s
Shell Sort : 602 K Items/s
Merge Sort : 1,284 K Items/s
Heap Sort : 866 K Items/s
Quick Sort : 2,938 K Items/s
Large Objects Sort : 901 K Items/s
Fast Fourier Transformg (Standard) : 2,151 KB/s
Fast Fourier Transformg (Optimized) : 5,561 KB/s
У меня 392 KB/s на 1000 upto 1500
Моя старая конфа за нумером 1
Mark to MHz ratio: 1.81 на К6-2+
в Винраре - убогие и жалкие 85KB/sec с разгоном против 75 в штате
конфа сестры (Barton 2500+@3200+ @ A7N8X-E + Kingston 2x256MB):
| Starting Hot CPU Tester Pro 4.2.2
| Initializing DefectTrack Engine version 2.1.1016
| Loading options...
| Reading system info...
| CPU: AMD Athlon(tm) XP 2500+
| Speed: 1837MHz
| -1
| 64
| 64
| L1 Cache Size: 128KB
| L2 Cache Size: 512KB
| L3 Cache Size: -1KB
| Hyper-Threading: FALSE
| SMP: FALSE
| Scanning SMBIOS...
| Could not read SMBIOS data
| Total Physical Memory: 536330240 bytes
| Availabe Physical Memory: 263831552 bytes
| Total Virtual Memory: 2147352576 bytes
| Availabe Virtual Memory: 2110881792 bytes
| Operating System: Windows 2000 Professional Service Pack 4
| Setting Process Priority...
| Starting Benchmark....
| Integer Addition : 594 K Instructions/s
| Integer Subtraction : 595 K Instructions/s
| Integer Multiplication : 446 K Instructions/s
| Integer Division : 42 K Instructions/s
| Floating-Point Addition : 510 K Instructions/s
| Floating-Point Subtraction : 515 K Instructions/s
| Floating-Point Multiplication : 510 K Instructions/s
| Floating-Point Division : 445 K Instructions/s
| MMX Addition : 574 K Instructions/s
| MMX Subtraction : 574 K Instructions/s
| MMX Multiplication : 442 K Instructions/s
| 3DNow! Addition : 344 K Instructions/s
| 3DNow! Subtraction : 340 K Instructions/s
| 3DNow! Multiplication : 344 K Instructions/s
| 3DNow! Division : 693 K Instructions/s
| SSE Addition : 289 K Instructions/s
| SSE Subtraction : 289 K Instructions/s
| SSE Multiplication : 289 K Instructions/s
| SSE Division : 57 K Instructions/s
| Memory memcpy Method : 1092 MB/s
| Memory C++ Method : 1066 MB/s
| Memory repmovsd Method : 1092 MB/s
| Memory FPU 64-bit Method : 1155 MB/s
| Memory Assembly 32-bit Method : 1059 MB/s
| Memory Assembly 64-bit Method : 1099 MB/s
| Memory MMX 32-bit Method : 1185 MB/s
| Memory MMX 128-bit Method : 1163 MB/s
| Memory SSE 128-bit Method : 1180 MB/s
| Memory SSE movntq 64-bit Method : 1684 MB/s
| Memory SSE movntq 128-bit Method : 1739 MB/s
| Memory SSE prefetch movntq 128-bit Method : 1807 MB/s
| Memory SSE movntps 128-bit Method : 1693 MB/s
| Memory SSE prefetch movntps 256-bit Method : 1849 MB/s
| Insetion Sort : 47 K Item/s
| Shell Sort : 1325 K Item/s
| Merge Sort : 2167 K Item/s
| Heap Sort : 1068 K Item/s
| Quick Sort : 5274 K Item/s
| Large Objects Sort : 829 K Item/s
| FFT Standard Method : 3100 KB/s
| FFT Optimized Method : 6427 KB/s
| Benchmark results: 5606 Score
| Mark to MHz ratio: 3.05
| Closing Hot CPU Tester Pro...
| ************ End of Session ************
WinRAR - 266KB/sec
по данным ivp:
CUV266-D - Metabench to MHz = 2.92 - в раствиканном, в дефолте - 2.89
еще, еще и еще. И до кучи вот
ПИТЕР - где есть качественные компьютерные барахолки ?
  • Michael Дык я вроде и
  • 2ivp Я ваще тоже удивился - чей это вы
  • Michael Так а на предмет
  • 2Root Кароче -)) Вызываю на дуель пиписик. Я
  • K9 Там были Торобреды-Б 2000@2600+... С
  • Root ivp уже мерял пиписьки.
  • в ВинРАРе и HotCPU Tester пророчу проигрыш
  • Root Хе,
  • 2root Ваще то этот комп с припаеным бартоном
  • нет. Туалатин с разгоном будет быстрее :P
  • Охренеть да и только , а
  • короче, меньше, чем за 100 у.е. P!!!-S
  • То, что Туалатино 1000/256/100 на Юноне стоит обычно
  • Baza Довольно давно учился по форуму
  • Где???
  • 2Root Ссори похоже я промахнулся насчет цен - просто
  • Ну, кто как - не знаю, пример
  • это где он столько стоит???? ivp
  • 2DanZer Вариант №2 и впрямь самый
  • У меня Master или Maestro, только наша
  • Вариант №2 - наличие друга с этой самой
  • 2Baza Там первое необходимое условие - наличие международной
  • Люди, научите правильно пользоваться Ebay-ем пжалста
  • да пожалуйста :) приезжайте исчо :)
  • Выражаю персональную благодарность Батьке, Root_у и Baza_е,
  • Michael , я живу в р-не Гражданки
  • 2Baza А я очень даже приму это предложение-
  • ЮНОНа -развал и пара лотков-ларьков Про Удельную уже
  • По поводу Удельной. Это - всего лишь бесконечно большая
  • Ну, сейчас-то уже со своего... А тот был
  • ivp сто пудоф с чужова
  • Michael Был на Юноне со
  • Machael Только-что прибыл из Питера. На Юноне цены как в
  • 2Root Вот спасибки -)) Очень ценная для меня инфа. Посещение
  • Michael Baza пока что отдыхает,
