лог патчера:
Found 2Mbit BIOS (6.x)!
Found AMD K7-BIOS/platform!
1. New
16 Июн 2005 - 11:37 Unknown BIOS
лог патчера:
1. New CPU Support : -> fixed.
1a.Bus Disconnect Support : -> fixed.
2. XP frequency :Can`t found frequency_st!
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : -> fixed.
14.Set "Y" as default on exit: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 40.8%
Adding start.tmp 87.5%
запускался безо всяких ключей кроме сохранения в файл
лог патчера:
