Не могу найти сам файл. Нашел только текстовый контент, надеюсь что поможет. Аналог чипа по крайней мере та-же разводка и програмирование ATI18810 (-1.-2), также поиши по аналогам контента:
ICS1394
Startech ST49c394
Trident TCK900x
20pin mask-programmable video frequency generator.
Pins:
1 i Frequency Select bit 3
2 i Address Latch Enable. Set high to latch new selectors.
3 i Digital Supply Voltage. Single +5V
4 i Frequency Select bit 4 or external clock input 1
5 i Crystal or external clock input.
6 o Crystal output
7 i External Clock Input 2
8 o Digital Ground
9 o Video Clock Output
12 i Analog Supply Voltage. Single +5V
17 o Analog Ground
18 i Frequency Select bit 0
19 i Frequency Select bit 1
20 i Frequency Select bit 2
The video clock is one of 16 or 32 programmed frequencies selected by pins
18,19,20,1 and possibly 4. If the chip is in 16closk mode the External Clock
Input (pin 4) can be used. The programmed clocks are calculated as:
(Reference clock *A)/(B*C)
Where A is 1..127, B is 1..127 and C is 1,2 or 4.
As this chip is mask programmable many versions exist:
ICS1394
Startech ST49c394
Trident TCK900x
Pins:
6 o Crystal output
8 o Digital Ground
17 o Analog Ground
ICS1394 -073
ST49c394 -24 -30
Trident: 9001 9002 9004
Chrontel: -593
VCLK 0: XTAL 25.175 14.318 25.175 25.175 25.275 25.175
VCLK 1: 16.257 28.322 16.257 28.322 28.322 28.322 28.322
VCLK 2: EXTFREQ 32.514 FREQ0 44.900 44.900 44.900...40.0
VCLK 3: 32.514 36.000 32.514 36.000 36 000 36.000 80.0
VCLK 4: 25.175 40.000 25.175 57.272 57.272 57.272 50.1
VCLK 5: 28.322 44.900 28.322 65.000 65.000 65.000 77.0
VCLK 6: 24.000 65.000 24.000 50.350 50.350 50.350 36.1
VCLK 7: 40.000 84.000 40.000 40.000 40.000 40.000 44.9
VCLK 8: 25.175 25.175 14.318 25.175 88.000 80.0
VCLK 9: 28.322 28.322 16.257 28.322 98.000 119.9
VCLK A: 36.000 40.000 FREQ0 118.000 130.1
VCLK B: 65.000 44.900 36.000 44.900 108.000 31.5
VCLK C: 44.900 32.514 25.175 72.000 72.000 110.1
VCLK D: 50.000 28.322 28.322 77.000 77.000 64.9
VCLK E: 56.000 36.000 24.000 80.000 80.000 74.9
VCLK F: 75.000 65.000 40.000 75.000 75.000 72.3
VCLK 10: 25.175 25.175 14.318
VCLK 11: 28.322 28.322 65.028
VCLK 12: 40.000 32.514 FREQ0
VCLK 13: 65.000 36.000 36.000
VCLK 14: 44.900 40.000 25.175
VCLK 15: 50.000 44.900 28.322
VCLK 16: 56.000 56.000 24.000
VCLK 17: 75.000 65.000 40.000
VCLK 18: 25.175 25.175 44.900
VCLK 19: 28.322 28.322 50.344
VCLK 1A: EXTFREQ 32.514 16.257
VCLK 1B: EXTFREQ 40.000 32.514
VCLK 1C: 60.000 44.900 56.644
VCLK 1D: 80.000 60.000 20.000
VCLK 1E: EXTFREQ 80.000 50.000
VCLK 1F: EXTFREQ 84.000 80.000
