Побродив по ссылкам из FAQ набрел на утилиту 48LBAChk скачал и запустил... Она же мне выдала полный бред...
Scanning System for Available ATA/ATAPI Devices:
Searching for Primary Master.....Searching for Primary Slave......Searching for
Secondary Master...Searching for Secondary Slave....
ATA Device Results:
Device 0, BIOS reports 37(GB), Device reports 0(GB)
Device 1, BIOS reports 149(GB), Device reports 0(GB)
Intel 48-bit LBA BIOS Test Complete --> UNDETERMINED
We cannot determine whether your BIOS is 48-bit LBA
capable, because you currently do not have a 48-bit
LBA hard drive installed.
However, the size of your hard drive(s) is not reported
correctly by the BIOS.
Please contact your motherboard or system manufacturer
for a possible BIOS update.
ОС Win98
