Все что ниже написано относитса к моделям перечилсенным
Все что ниже написано относитса к моделям перечилсенным в первом обзаце (в принципе применимо и к другим но_етот_список точно) ПОСТ коды, бипы, пост мессаги и кое чаго ищо для компака и павилиона, ево, пресарио
HP Pavilion ze5600 Notebook PC
HP Pavilion ze5500 Notebook PC
HP Pavilion ze5400 Notebook PC
HP Pavilion ze5300 Notebook PC
HP Pavilion ze5200 Notebook PC
HP Pavilion ze4700 Notebook PC
HP Pavilion ze4600 Notebook PC
HP Pavilion ze4500 Notebook PC
HP Pavilion ze4400 Notebook PC
HP Pavilion ze4300 Notebook PC
HP Pavilion ze4200 Notebook PC
HP Pavilion ze4100 Notebook PC
HP Compaq nx9010 Notebook PC
HP Compaq nx9008 Notebook PC
HP Compaq nx9005 Notebook PC
HP Compaq nx9000 Notebook PC
Compaq Evo Notebook N1050v Series
Compaq Evo Notebook N1010v Series
Compaq Presario 2500 Series Mobile PC
Compaq Presario 2100 Series Mobile PC
Compaq Presario 1100 Series Mobile PC
(All Models that use technology code KE)
POST Terminal-Error Beep Codes
Beep Codes POST Description
1 One short beep before boot
1-2 Search for option ROMs
1-1-1-3 Verify Real Mode
1-1-1-4 Disable Non-Maskable Interrupt (NMI)
1-1-2-1 Get CPU type
1-1-2-3 Initialize system hardware
1-1-2-4 Disable shadow and execute code from ROM
1-1-3-1 Initialize chipset with initial POST values
1-1-3-2 Set IN POST flag
1-1-3-3 Initialize CPU registers
1-1-3-4 Enable CPU cache
1-1-4-1 Initialize caches to initial POST values
1-1-4-3 Initialize I/O component
1-1-4-4 Initialize local bus IDE
1-2-1-1 Initialize Power Management
1-2-1-2 Load alternate registers with initial POST values
1-2-1-3 Restore CPU control word during warm boot
1-2-1-4 Initialize PCI Bus Mastering devices
1-2-2-1 Initialize keyboard controller
1-2-2-3 BIOS ROM checksum
1-2-2-4 Initialize cache before memory Auto size
1-2-3-1 8254 timer initialization
1-2-3-3 8237 DMA controller initialization
1-2-4-1 Reset Programmable Interrupt Controller
1-3-1-1 Test DRAM refresh
1-3-1-3 Test 8742 Keyboard Controller (on motherboard)
1-3-2-1 Set ES segment register to 4 GB
1-3-3-1 Auto size DRAM; or wrong type or no RAM installed
1-3-3-2 Initialize POST Memory Manager
1-3-3-3 Clear 512 KB base RAM
1-3-4-1 RAM failure on address line xxxx
1-3-4-3 RAM failure on data bits xxxx of low byte of memory bus
1-3-4-4 Enable cache before system BIOS shadow
1-4-1-1 RAM failure on data bits xxxx of high byte of memory bus
1-4-1-3 Test CPU bus-clock frequency
1-4-1-4 Initialize Phoenix Dispatch Manager
1-4-2-3 Warm start shut down
1-4-3-1 Shadow system BIOS ROM
1-4-3-3 Auto size cache
1-4-4-1 Advanced configuration of chipset registers
1-4-4-2 Load alternate registers with CMOS values
2-1-1-2 Initialize extended memory for ROMPilot
2-1-1-3 Initialize interrupt vectors
2-1-2-2 POST device initialization
2-1-2-3 Check ROM copyright notice
2-1-2-4 Initialize I20 support
2-1-3-1 Check video configuration against CMOS
2-1-3-2 Initialize PCI bus and devices
2-1-3-3 Initialize all video adapters in system
2-1-3-4 QuietBoot start (optional)
2-1-4-1 Shadow video BIOS ROM
2-1-4-3 Display BIOS copyright notice
2-1-4-4 Initialize MultiBoot
2-2-1-1 Display CPU type and speed
2-2-1-2 Initialize EISA board
2-2-1-3 Test keyboard
2-2-2-1 Set key Select if enabled
2-2-2-2 Enable USB devices
2-2-3-1 Test for unexpected interrupts
2-2-3-2 Initialize POST display service
2-2-3-3 Display prompt "Press F2 to enter SETUP"
2-2-3-4 Disable CPU cache
2-2-4-1 Test RAM between 512 and 640 KB
2-3-1-1 Test extended memory
2-3-1-3 Test extended memory address lines
2-3-2-1 Jump to UserPatch1
2-3-2-3 Configure advanced cache registers
2-3-2-4 Initialize Multi Processor APIC
2-3-3-1 Enable external and CPU caches
2-3-3-2 Set up System Management Mode (SMM) area
2-3-3-3 Display external L2 cache size
2-3-3-4 Load custom defaults (optional)
2-3-4-1 Display shadow-area message
2-3-4-3 Display possible high address for UMB recovery
2-4-1-1 Display error messages
2-4-1-3 Check for configuration errors
2-4-2-3 Check for keyboard errors
2-4-4-1 Set up hardware interrupt vectors
2-4-4-2 Initialize Intelligent System Monitoring
2-4-4-3 Initialize coprocessor if present
3-1-1-1 Disable onboard Super I/O ports and IRQs
3-1-1-2 Late POST device initialization
3-1-1-3 Detect and install external RS232 ports
3-1-1-4 Configure non-MCD IDE controllers
3-1-2-1 Detect and install external parallel ports
3-1-2-2 Initialize PC-compatible PnP ISA devices
3-1-2-3 Re-initialize onboard I/O ports
3-1-2-4 Configure Motherboard Configurable Devices (optional)
3-1-3-1 Initialize BIOS Data Area
3-1-3-2 Enable Non-Maskable Interrupts (NMIs)
3-1-3-3 Initialize Extended BIOS Data Area
3-1-3-4 Test and initialize PS/2 mouse
3-1-4-1 Initialize floppy controller
3-1-4-4 Determine number of ATA drives (optional)
3-2-1-1 Initialize hard-disk controllers
3-2-1-2 Initialize local-bus hard-disk controllers
3-2-1-3 Jump to UserPatch2
3-2-1-4 Build MPTABLE for multi-processor boards
3-2-2-2 Install CD-ROM for boot
3-2-2-3 Clear huge ES segment register
3-2-2-4 Fix up Multi Processor table
3-2-3-2 Check for SMART Drive (optional)
3-2-3-3 Shadow option ROMs
3-2-4-1 Set up Power Management
3-2-4-2 Initialize security engine (optional)
3-2-4-3 Enable hardware interrupts
3-2-4-4 Determine number of ATA and SCSI drives
3-3-1-1 Set time of day
3-3-1-3 Check key lock
3-3-2-1 Initialize typematic rate
3-3-3-1 Erase F2 prompt
3-3-3-3 Scan for F2 keystroke
3-3-4-1 Enter SETUP
3-3-4-3 Clear Boot flag
3-4-1-1 Check for errors
3-4-1-2 Inform ROMPilot about the end of POST
3-4-1-3 POST done—prepare to boot OS
3-4-2-2 Terminate QuietBoot (optional)
3-4-2-3 Check password (optional)
3-4-2-4 Initialize ACPI BIOS
3-4-3-2 Prepare Boot
3-4-3-3 Initialize SMBIOS
3-4-3-4 Initialize PnP Option ROMs
3-4-4-1 Clear parity checkers
3-4-4-2 Display MultiBoot menu
3-4-4-3 Clear screen (optional)
3-4-4-4 Check virus and backup reminders
4-1-1-1 Try to boot with INT 19
4-1-1-2 Initialize POST Error Manager (PEM)
4-1-1-3 Initialize error logging
4-1-1-4 Initialize error display function
4-1-2-1 Initialize system error handler
4-1-2-2 PnPnd dual CMOS (optional)
4-1-2-3 Initialize note dock (optional)
4-1-2-4 Initialize note dock late
4-1-3-1 Force check (optional)
4-1-3-2 Extended checksum (optional)
4-1-3-3 Redirect Int 15h to enable remote keyboard
4-1-3-4 Redirect Int 13h to Memory Technologies Devices such as ROM, RAM, PCMCIA,
and serial disk
4-1-4-1 Redirect Int 10h to enable remote serial video
4-1-4-2 Re-map I/O and memory for PCMCIA
4-1-4-3 Initialize digitizer and display message
4-2-1-3 Unknown interrupt
4-3-1-1 Initialize the chipset
4-3-1-2 Initialize the bridge
4-3-1-3 Initialize the CPU
4-3-1-4 Initialize system timer
4-3-2-1 Initialize system I/O
4-3-2-2 Check force recovery boot
4-3-2-3 Checksum BIOS ROM
4-3-2-4 Go to BIOS
4-3-3-1 Set Huge Segment
4-3-3-2 Initialize Multi Processor
4-3-3-3 Initialize OEM special code
4-3-3-4 Initialize PIC and DMA
4-3-4-1 Initialize Memory type
4-3-4-2 Initialize Memory size
4-3-4-3 Shadow Boot Block
4-3-4-4 System memory test
4-4-1-1 Initialize interrupt vectors
4-4-1-2 Initialize Run Time Clock
4-4-1-3 Initialize video
4-4-1-4 Initialize System Management Manager
4-4-2-1 Output one beep
4-4-2-2 Clear Huge Segment
4-4-2-3 Boot to Mini DOS
4-4-2-4 Boot to Full DOS
1 long,2 short: Improper video configuration (reprogram EEPROM) or external ROM checksum failure.
POST Messages
Message Description
0200 Failure Fixed Disk Fixed (hard) disk is not working or not configured properly Make sure the hard
disk is installed properly Run BIOS Setup and make sure the hard disk type is
correctly identified
0210 Stuck key Stuck key on keyboard
0211 Keyboard error Keyboard is not working
0212 Keyboard Controller
Failed
Keyboard controller failed the test Might require replacing the motherboard
(contains the keyboard controller)
0213 Keyboard locked—
Unlock key switch
Unlock the system to proceed
0220 Monitor type does not
match CMOS—Run SETUP
Monitor type is not correctly identified in BIOS Setup
0230 Shadow RAM Failed at
offset: nnnn
Shadow RAM failed at offset nnnn of the 64k block at which the error was
detected
0231 System RAM Failed at
offset: nnnn
System RAM failed at offset nnnn of the 64k block at which the error was
detected
0232 Extended RAM Failed
at offset: nnnn
Extended memory is not working or not configured properly at offset nnnn
Update to the latest BIOS version
0250 System battery is
dead—Replace and run
SETUP
CMOS clock battery indicator shows that the CMOS battery is dead Connect
the AC adapter
for at least 24 hours, and then run BIOS Setup to reconfigure the system
0251 System CMOS
checksum bad—Default
configuration used
System CMOS has been corrupted or modified incorrectly, perhaps by an
application that changes CMOS data In response, the BIOS has installed the
default Setup values Use BIOS Setup to modify these values if needed If the
error persists, check the system battery Connect the AC adapter for at least
24 hours; replace the motherboard
0260 System timer error Timer test failed Replace the motherboard
0270 Real time clock error Real-time clock failed the BIOS test Might require replacing the motherboard
0271 Check date and time
settings
BIOS found the date or time to be out of range, and then reset the real-time
clock You might need to use BIOS Setup to reset the legal date
0280 Previous boot
incomplete—Default
configuration used
Previous POST did not complete successfully POST loads default values and
offers to run BIOS Setup If the failure was caused by incorrect values that are
not corrected, the next boot will likely fail This error is cleared the next time
the system is booted
0281 Memory Size found by
POST differed from CMOS
Memory size found by POST differed from that specified in CMOS
02B0 Diskette drive A error Drive A: is present but fails the BIOS POST diskette tests Make sure the drive
is defined with the proper diskette type in BIOS Setup, and that the drive is
connected correctly
02B2 Incorrect Drive A
type—run SETUP
Type of floppy drive A: not correctly identified in BIOS Setup
02D0 System cache error—
Cache disabled
RAM cache failed and BIOS disabled the cache May require replacing the
motherboard A disabled cache slows system performance considerably
02F0: CPU ID CPU socket number for Multi-Processor error
02F4: EISA CMOS Not
Writeable
ServerBIOS2 test error: Cannot write to EISA CMOS
02F5: DMA Test Failed ServerBIOS2 test error: Cannot write to extended Direct Memory Access
(DMA) registers
02F6: Software NMI Failed ServerBIOS2 test error: Cannot generate software Non-Maskable Interrupt
(NMI)
02F7: Fail-Safe Timer NMI
Failed
ServerBIOS2 test error: Fail-safe timer takes too long
device Address Conflict Address conflict for the specified device
Allocation Error for: device Run ISA or EISA Configuration Utility to resolve a resource conflict for the
specified device
CD ROM Drive CD-ROM drive identified
Entering SETUP Starting BIOS Setup
Failing Bits: nnnn Hex number nnnn is a map of the bits at the RAM address that failed the
memory test Each
1 (one) in the map indicates a failed bit See errors 230, 231, or 232 above for
offset address
of the failure in System, Extended, or Shadow memory
Fixed Disk n Fixed disk n (0–3) identified
Invalid System
Configuration Data
Problem with NVRAM (CMOS) data
I/O device IRQ conflict I/O device IRQ conflict error
PS/2 Mouse Boot Summary
Screen:
PS/2 mouse installed
nnnn kB Extended RAM
Passed
Where nnnn is the amount of RAM in KB successfully tested
nnnn Cache SRAM Passed Where nnnn is the amount of system cache in KB successfully tested
nnnn KB Shadow RAM
Passed
Where nnnn is the amount of shadow RAM in KB successfully tested
nnnn KB System RAM
Passed
Where nnnn is the amount of system RAM in KB successfully tested
Operating system not
found
Operating system cannot be located on drive A: or drive C: Enter BIOS Setup
and see if the hard disk and drive A: are properly identified
Parity Check 1 nnnn Parity error found in the system bus BIOS attempts to locate the address and
display it on the screen Parity is a method for checking errors in binary data A
parity error indicates that data
has been corrupted
Parity Check 2 nnnn Parity error found in the I/O bus BIOS attempts to locate the address and
Press to resume,
to Setup, for previous
Displayed after any recoverable error message Press to start the boot
process or to enter BIOS Setup and change the settings Press to
display the previous screen (usually an initialization error of an Option ROM,
such as an add-on card) Write down and follow the information shown on the
screen
Press to enter Setup Optional message displayed during POST
PS/2 Mouse PS/2 mouse identified
System BIOS shadowed System BIOS copied to shadow RAM
UMB upper limit segment
address: nnnn
Displays the address nnnn of the upper limit of Upper Memory Blocks (UMB),
indicating released segments of the BIOS that can be reclaimed by a virtual
memory manager
Video BIOS shadowed Video BIOS copied to shadow RAM
Кандидаты в ФАК
  • http://pq.ozersk.ru/ftp/hardware/ - про старенькое железо В довесок - конфа
  • http://www.zigzag-pvl.by.ru/ - заправка струйников
  • http://www.telemaster.ru/
  • www.hub.ru работает - только что проверил. Я, вообще-то,
  • HUB.ru работает.. можт падал?
  • DanZer Что-то ничего кроме дефолтной
  • Сайт по сетям - домашним и диким :)
  • Полезные журналы: Электронные компоненты Живая Электроника Росии
  • http://www.martini-man.com/pub/ - Сервис-мануалы на ноубуки HP - БИОСы
  • rgt нарыл еще: http://www.amdcompare.com/us-en/desktop/ Дейстивтельно, processor finder теперь не
  • Доки по принтерам: http://www.scc-inc.com/default2.aspx
  • Root Эта ссылка, надеюсь, уже
  • Вау! Все, наверное, помнят Processor
  • Не плохой фак для людей, которые хотели бы
  • 2 egor - Не могли бы Вы сделать
  • http://www.matrix-bios.nl/ Довольно интересный сайт с кучей полезной инфы, как
  • http://www.etherboot.org сайт с прошивками для сетевух (бутромы) http://www.plasma-online.com/ всем известный сайт.... http://www.idhw.com/ IDentify
  • Спасибо. :)
  • Было умирание винта вместе с базой, потом
  • Нашел вот прилюбопытнейшую статью может пригодится кому http://mcmcc.bat.ru/vlan/
  • Service manuals, schematics, documentation, programs, electronics, hobby http://www.eserviceinfo.com/ Ловите
  • Хорошо бы еще, чтобы теперь это (и последующее)
  • http://bp.kmdc.ru/index.php?newlang=rus http://katalog.elektroda.net/indx00-74HC.html http://epu.ref.nstu.ru/DISKOTEKA/ http://www.datasheetcatalog.com/datasheets_pdf/M/2/9/W/M29W160ET.shtml http://www.radanpro.com/el/datasheets_cd.php http://www.romservice.ru/proizvodit.html http://mosfet.data-chip.ru/f/vtc410 http://ham.kiev.ua/sprav/ Всё что было нажито непосильным трудом :) http://www.techno.ru/4_1.htm Енто про
  • http://www.epanorama.net/index.php аналогично
  • Да, что-то у них там сегодня колбасило
  • База даташитов Гляньте http://www.chip.tomsk.ru/chip/chipdoc.nsf?OpenDatabase Пардон. У них какието проблемы с
  • http://www.smps.us/ ресурс по силовой электронике
  • http://www.project857.narod.ru/topic/download/vs_id_setup.zip - то жесамое только программка (и
  • Предлагаю в эту тему заносить возможные кандидатуры для
  • http://www.eserviceinfo.com/browse.php (не реклама: сегодня наткнулся)
  • Сегодня наткнулся на залежи! Кому надо вот ссылки: http://www.ruisch.tk/ http://members.home.nl/jsruisch/BIOS%20UTILITIES/AMI/ http://www.drunkardswalk.dk/bno/BNOBTC.rar http://www.geocities.com/mamanzip/Articles/AdvancedBiosModGuide/Advanced_Bios_Hacking.html
  • http//www.ongood.com.tw/tech/SOFTWARE/software.htm жаль, по китайски, некоторое количество ромов от сетевых
  • http://www.mpoli.fi/files/hardware/ROM/OTHER/ http://www.zdnet.de/treiber/products/mainboard-bios-wc.html себе нашел кое-что, и Вам всем даю... пусть админы
  • Вот ссылочка: http://wims.rainbow-software.org/index.php?count=-1 Может кто мне спасибо скажет...
  • Нашел интересную статью об ограничениях на объем винтов:
