Аналогичной - имеется в виду H61DEL? Или
amsokol писал(-а):
Но тем не менее на аналогичной маме этих 28 ом нет
Аналогичной - имеется в виду H61DEL? Или матплата на базе H61/X6x другого производителя?
amsokol писал(-а):
где можно почитать
На 1-ой странице документации RT8859M писал(-а):
Features
- 4/3/2/1 + 1 Phase PWM Controller
Где-то в середине документации RT8859M писал(-а):
Active Phase Determination : Before POR
The number of active phases is determined by the internal circuitry that monitors the ISENxN voltages during start-up. Normally, the CORE VR operates as a 4-phase PWM controller. Pulling ISEN4N to VCC programs a 3-phase operation, pulling ISEN3N and ISEN4N to VCC programs a 2-phase operation, and pulling ISEN2N, ISEN3N and ISEN4N to VCC programs a 1-phase operation.
Phase selection is only active during POR. When POR = high, the number of active phases is determined and latched. The unused ISENxP pins are recommended to be connected to VCC and unused PWM pins can be left floating.
Не стартует asrock h61del
