Switches can be found via the /? switch, but the only ones available in that program are as follows
/C - Clear DMI pool data
/D - Load CMOS defaults
/E - Clear CMOS
/R - Reboot System
/S - Save Original
You could use awardflash, but it only has the following
/CC = clear CMOS data after programming.
/CD = clear DMI data after programming.
/CP = clear PnP (ESCD) data after programming.
/QI = use BIOS I.D. string from BIOS .bin file.
/R = reset system after programming.
/PY = program flash memory.
/F = Flash BIOS
/SN = don't save existing BIOS.
не факт, что эти ключи работают на всех версиях, так что лучше все-таки программатором
uniflash, к сожалению, заброшен? пробуйте flashrom, тогда уж
/E - Clear CMOS
/R - Reboot System
/S - Save Original
/F = Flash BIOS
