Команды командной строки (тавтология) есть в winflash.chm того
Команды командной строки (тавтология) есть в winflash.chm того файла, который я прикрепил, но отдельно напишу.
Command Options
This section lists WinFlash command options and parameters.
Syntax
WINFLASH [options] [romfile] [@rspfile]
romfile
The new BIOS image name, eg: BIOS.FD
@rspfile
The response file (PFLASH.RSP by default) contains all command parameters in text format.
/? or /help or /h
Displays help screen
/all
Flash the entire image including the descriptor region
/bak:filename
Backup ROM to a file.
/bbl
Program the boot block. By default, bootblock is not updated.
/bios
Flash the BIOS region
/cs
Verify BIOS.FD image checksum
/cvar
Clear variables
/desc
Flash the descriptor the region
/dmc:string
Specify chassis manufacturer DMI string
/dmm:string
Specify motherboard manufacturer DMI string
/dms:string
Specify system manufacturer DMI string
/dcp:string
Specify chassis asset tag number
/dpm:string
Specify motherboard product ID DMI string
/dps:string
Specify system product ID DMI string
/dsc:string
Specify chassis serial number DMI string
/dsm:string
Specify motherboard serial number DMI string
/dss:string
Specify system serial number DMI string
/dus:string
Specify UUID DMI string
/dvc:string
Specify chassis version DMI string
/dvm:string
Specify motherboard version DMI string
/dvs:string
Specify system version DMI string
/ec
Flash the EC region
/exit
Exit without rebooting
/gbe
Flash the GbE region
/logo:imagefile
Replace the current BIOS logo with an imagefile in jpeg or bmp format.
/me
Flash the ME region
/mfg
Manufacturing mode. Automatically reboots without the need for pressing a key.
/mod:filename
Updates the module in the BIOS with the module contained in the file (such as /MOD:vga.ffs); the rest of the BIOS image remains unchanged.
/mode=n
Specify dmi mode n = {0, 1, 2, 3}
0: Just update BIOS with new file, don’t update DMI variables.
1: Just update DMI variables, keep ROM BIOS as before.
2: Update BIOS, merge ROM DMI variables with command line(default).
3: Update BIOS, merge image variables with command line.
/p
Production mode (minimize messages and delays)
/raw:uuid:filename
Replace the RAW module content.
/remote2
Execute WinFlash without GUI, allowing other applications or other computers to call WinFlash.
/ro[=name]
Read contents of flash part and save to a file.
/v
Verify each block after programming it.
/sa
Skip all BIOS checks.
/sd
Skip BIOS date check.
/sn
Skip BIOS part number check.
/sp
Skip BIOS product code check.
/sv
Skip BIOS version check.
C этого места можно подробнее, что и как не так?
Моё мыло в заголовке проги указано.
Нельзя, потому что уже просто не помню... Но если еще раз в это полезу, то посмотрю обязательно.
