Всё прошло удачно. Спасибо на добром совете.
Вот лог:
27 Янв 2005 - 21:46 Unknown BIOS
Вот лог:
BIOS Patcher ver. 4.23.
Found 2Mbit BIOS (4.5x)!
1. New CPU Support : -> fixed.
2. P3-detect error : -> fixed.
3. New Koeffs Support : -> fixed.
4. 32Gb-problem : -> fixed.
5. Some HDD detect-problem : -> fixed.
6. "MB"/"GB" string search : -> fixed.
7. 65Gb-problem (1-st step) : -> fixed.
8. 65Gb-problem (2-nd step) : -> fixed.
9. Error display Freq>999MHz : -> fixed.
10.Error display Koefs>9.5x : not found.
Fixed wrong CPUID display.
11.New Stepping Support : -> fixed.
12.Tualatin L2-init error : -> fixed.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: -> fixed.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 35.4%
Adding start.tmp 87.5%
Adding cpucode.bin 55.9%
ROOT
угу.. Ссылка очень даже живая.. ivp, респект!
Вот лог:
У меня всё равно не открывается...
