" Koeffs Support " addition in BIOS the data for "understanding" CPU Ratio for Tualatin
( Basically Tualatin works and without it. A problem in correct display of frequency of the processor)
What the processor works and - or will work?
I shall be grateful if you will send me Bios on E-mail:fc_arsenal@ukr.net
Vcc realy in VRM 8.4 it Is adjusted from 1.3 up to 3.5 on cheap (Acorp, Iwill, etc.) Mainboard it setting hardware. On MSI, Asus, Abit and similar mums it is usually setting in Bios
