CD001 - сигнатура (маленькая часть) заголовка (volume descriptor
CD001 - сигнатура (маленькая часть) заголовка (volume descriptor'а). В общем - если ее нет, то это мусор. Заголовок вот:
typedef unsigned char Byte;
typedef unsigned short Word;
typedef unsigned long Long;
typedef struct
    Byte    VDType;                 /* Must be 1 for primary volume
                                       descriptor. */
    char    VSStdId[5];             /* Must be "CD001". */
    Byte    VSStdVersion;           /* Must be 1. */
    Byte    volumeFlags;            /* 0 in primary volume
                                       descriptor. */
    char    systemIdentifier[32];   /* What system this CD-ROM is
                                       meant for. */
    char    volumeIdentifier[32];   /* The volume name. */
    char    Reserved2[8];           /* Must be 0's. */
    Long    lsbVolumeSpaceSize;     /* Volume size, least-significant
                                       -byte order. */
    Long    msbVolumeSpaceSize;     /* Volume size, most-significant
                                       -byte order. */
    char    escapeSequences[32];    /* 0's in primary volume
                                       descriptor */
    Word    lsbVolumeSetSize;       /* Number of volumes in volume
                                       set (must be 1). */
    Word    msbVolumeSetSize;
    Word    lsbVolumeSetSequenceNumber;/* Which volume in volume set
                                          (not used). */
    Word    msbVolumeSetSequenceNumber;
    Word    lsbLogicalBlockSize;    /* We'll assume 2048 for block
                                       size. */
    Word    msbLogicalBlockSize;
    Long    lsbPathTableSize;       /* How many bytes in path
                                       table. */
    Long    msbPathTableSize;
    Long    lsbPathTable1;          /* Mandatory occurrence. */
    Long    lsbPathTable2;          /* Optional occurrence. */
    Long    msbPathTable1;          /* Mandatory occurrence. */
    Long    msbPathTable2;          /* Optional occurrence. */
    char    rootDirectoryRecord[34];   /* Duplicate root
                                          directory entry. */
    char    volumeSetIdentifier[128];  /* Various copyright and
                                          control fields follow. */
    char    publisherIdentifier[128];
    char    dataPreparerIdentifier[128];
    char    applicationIdentifier[128];
    char    copyrightFileIdentifier[37];
    char    abstractFileIdentifier[37];
    char    bibliographicFileIdentifier[37];
    char    volumeCreation[17];
    char    volumeModification[17];
    char    volumeExpiration[17];
    char    volumeEffective[17];
    char    FileStructureStandardVersion;
    char    Reserved4;               /* Must be 0. */
    char    ApplicationUse[512];
    char    FutureStandardization[653];
} PVD, *PVDPtr;
