Hello, @Kollis: How did you get clean output from
Hello,
@Kollis: How did you get clean output from that drive? I managed to get the output with rubbish:
CLI> PINRST
*** ROM 106 Mar 12 2009 20:29:35 ***
FW_SRC 0 SHA PASS!
*** EEPROM 207 Jan 3 2011 18:36:27 BuildServer:FW_Common_Critical_Fixes:P1_EEPROM_2_0_7_drop-290232 ***
IMFT45 Timing EPch
*** Patch 1.4.1 Mar 10 2011 16:23:47 BuildServer:P1_3_6_0_MP4_7:P1_3_6_0_MP4_7-300475 ***
IMFT45 Timing EPch
RCPch SAK0
ÿÿÿÿÿ\_ýÞýÞýÞø^(_ýÞýÞýÞm—ŒýÞÿÿÿÿìcýÞýÞýÞýÞýÞýÞÂvÄ1ýÞUdP‡
ýÞýÞýÞÿÿÿÕýÞýÞÕýÞýÞ .... and so on.
I'm using following COM settings:
Baud rate: 115200
Data bits: 8
Stop bits: 1
Parity, Flow control: None
Did you managed to do any further operations through that terminal? Any chances to read raw data from flash or to get it to be seen again by BIOS?
Thanks
