Kind help request from italy.
I have got one 7200.12 here. Not seen by bios. Thank you for any help.
When I connect it to terminal, after Ctrl-Z, this is the output: ----terminal output---- F3 T> RAW OFF
(P) SATA Reset ----end of terminal----
After some tricks I've have been able to format m0,2,2,,,,,22 and also N1 Then I turned off and on the disk but the result is again
any idea or suggestion or hint?
Thank you if any Corsari
F3 T>
RAW OFF
(P) SATA Reset
F3 T>
RAW OFF
(P) SATA Reset
Thank you if any
Corsari
