Автор: SpyFlash , 21 апреля 2011
Hi all,
I have some problem with my newton's power supply. The purple line have 5 volts but it can't start.
Then i decided to replace caps in secondary side but nothing change.
If anyone can help me please tell me howto fix it.
I attached some pictures of this power supply.
http://images.temppic.com/21-04-2011/images_vertis/1303360821_0.61997400.jpg
http://images.temppic.com/21-04-2011/images_vertis/1303360822_0.03474700.jpg
http://images.temppic.com/21-04-2011/images_vertis/1303360822_0.42686200.jpg
http://images.temppic.com/21-04-2011/images_vertis/1303360822_0.81690900.jpg
http://images.temppic.com/21-04-2011/images_vertis/1303360823_0.18954400.jpg
SpyFlash
15 лет 7 месяцев назад
hi UAM,
here is some pics of output voltage on coupler. but i not sure which one you need.
http://images.temppic.com/25-04-2011/images_vertis/1303664659_0.82531700.jpg
http://images.temppic.com/25-04-2011/images_vertis/1303664660_0.20339000.jpg
http://images.temppic.com/25-04-2011/images_vertis/1303664660_0.57940600.jpg
Are these pictures help us.
SpyFlash
How u think? someone told me to buy new one but I want to repair it.
Is it hard to repair? Or we must leave it?
15 лет 6 месяцев назад
I do not understand why voltage on the second photo almost 9 volts? In standby mode, since only 5.
SpyFlash
Hi UAM,
standby mode??
in my testing , i already short green to black line. Is it wrong?
Yes. In standby.
In all modes between 1 and 2 PIN optocoupler MAX. Forward voltage VF IF = 20mA - 1.4 V
For exampe use https://rom.by/files/SUNNY_ATX-230.zip
IC4 - standby power - In all modes between PIN 1 and 2 - ~ 1.2v .
IC2 - operate power. In standby mode between ground (black wire) and PIN 1 or 2 = 0v
IC3 - ON/OFF operate mode. In standby mode between ground (black wire) and PIN 1 or 2 = 5v
