T F Set Stuff ASCIFE T F
T>F
Set Stuff> ASCIFE
T>F
Set stuff> ASCI83xxxxxxxxx (xxxxxxxxx-MaxLBA в НЕХ)
T>F
Set stuff> ASCI1Bxxxxxxxxx (имя в ASCI)
(xxxxxxxxx-MaxLBA в НЕХ) ---ДЛЯ 60 БАРРЫ......а то я что то не то туда пишу.блин......
See repair Seagate 's Stuff Was Unreadable, the plant model into the T-class, enter the F command, rewrite the hard drive 's parameters, then enter ASCI1B, then enter the hard drive model with the ASCII code (16 hex) to represent, such as ST340016A to enter 535433343030313641, while the value entered in 31 of 20 followed by the command line and prompt the following statement
T> F
SetStuff-> ASCI1B5354333130303136412020202020202020202020202020202020202020202020 (carriage return)
Stuff key 1b -> 53 54 33 31 30 30 31 36 41 20 20 20 20 20 20 20 20 20 20 20 20 2
0 20 20 20 20 20 20 20 20 20 20 ff ff ff ff ff ff ff ff
Once at the command input F, the STRUFF enter ASCI83, followed by hard drive capacity , capacity needs to be expressed in hexadecimal numbers, such as ST340016A disk input 2D5C012A, enter the address of the command line as follows:
T> F
SetStuff-> ASCI832D5C012A (carriage return)
Stuff key 83 -> 2d 5c 01 2a
We then enter the F command, and then enter the STRUFF ASCI3C, followed by hard drive capacity, also is expressed in hexadecimal numbers, the Executive after the press CTRL + T again to start the test command line format is as follows
T> F
SetStuff-> ASCI3C2D5C012A
Stuff key 3c -> 2d 5c 01 2a
Seagate hard drives for a variety of Replies KEY 1B, 83,3 C values, for reference:
Factory card through a terminal key editing
1,3,6 on the key, use the standard value, respectively, 3FFF, 0010 and 003F;
On key 1B, 3C, 83, shown in the following table:
1B key sequence key type 3C, 83
5354333130323131412020202020202020202020
ST310211A 2C61012A
5354333135333131412020202020202020202020
ST315311A A50101BF
5354333230343133412020202020202020202020
Seagate U5 ST320413A A7810254
2620202020202020202020202020202020202020
5354333330363231412020202020202020202020
ST330621A AC81037E
5354333430383233412020202020202020202020
ST340823A B57104A8
5354333330303132412020202020202020202020
ST330012A AC81037E
2020202020202020202,020202020202020202020
5354333430303132412020202020202020202020
ST340012A B57104A8
5354333630303132412020202020202020202020
Seagate U7 ST360012A CF3106FC
5354533830303232412020202020202020202020
ST380022A F8890950
5354333132303032304120202020202020202020
ST3120020A 4BB10DF9
5354333230303135412020202020202020202020
Seagate ST320015A A7810254
Barracuda 5400.1
5354333430303135412020202020202020202020
(Grand 2C) ST340015A B57104A8
5354333130303134414345202020202020202020
ST310014ACE 43130131
Seagate Ux
5354333230303134412020202020202020202020
ST320014A A7810254
5354333638313041202020202020202020202020
ST36810A Note A5BC00CB
5354333130323230412020202020202020202020
Seagate ST310220A 43130131
Barracuda ATA
(Rango) ST313620A 5354333133363230412020202020202020202020 4CA90197
Note: ST36810A the ST320430A 5354333230343330412020202020202020202020 8EF10263
Key 1 372В,
5354333237323730412020202020202020202020
Key 3 = 000F ST327270A 9951032E
5354333238303430412020202020202020202020
ST328040A FA21035I
5354333130323130412020202020202020202020
ST310210A 0B790130
Seagate 5354333135333230412020202020202020202020
ST315320A 113501C8
Barracuda 2020202020202020202020202020202020202020
ATA II 5354333230343230412020202020202020202020
ST320420A 16F10260
(Vail) 2020202020202020202020202020202020202020
5354333330363330412020202020202020202020
ST330630A 22690390
5354333130323135412020202020202020202020
ST310215A 0B790130
5354333135333130412020202020202020202020
ST315310A 113501C8
Seagate 2020202020202020202020202020202020202020
Barracuda 5354333230343134412020202020202020202020
ST320414A A7810254
ATA III 2020202020202020202020202020202020202020
(Aspen) 5354333330363230412020202020202020202020
ST330620A AC81037E
5354333430383234412020202020202020202020
ST340824A B57104A8
5354333230303131412020202020202020202020
ST320011A A7810254
Seagate 5354333430303136412020202020202020202020
ST340016A B57104A8
ATA IV 5354333630303231412020202020202020202020
ST360021A CF31O6FC
(Snowmass) 2020202020202020202020202020202020202020
5354333830303231412020202020202020202020
ST380021A F8B00950
5354333330303133412020202020202020202020
ST330013A AC81037E
5354333430303137412020202020202020202020
ST340017A B57104A8
Seagate
5354333630303135412020202020202020202020
Barracuda ATA V ST360015A CF3106FC
(Avalanche)
5354333830303233412020202020202020202020
ST380023A F8B00950
5354333132303032334120202020202020202020
ST3120023A 4BB10DF9
5354333430303134412020202020202020202020
ST340014A B57104A8
5354333830303131412020202020202020202020
ST380011A F8B00950
ST380013A F8B00950
5354333830303133412020202020202020202020
ST3120022A 4BB10DF9
5354333132303032324120202020202020202020
ST3120026A 4BB10DF9
5354333132303032364120202020202020202020
ST3160021A 9EBI12A1
5354333136303032314120202020202020202020
Seagate ST3160023A 9EB112A1
Barracuda 7200.7
5354333136303032334120202020202020202020
(Alpine) ST340014AS B57104A8
5354333430303134415320202020202020202020
ST380011AS F8B00950
5354333830303131415320202020202020202020
ST380013AS F8B00950
5354333132303032324153202020202020202020
ST3120022AS 4BB10DF9
ST3120026AS 4BB10DF9
5354333136303032314153202020202020202020
ST316002IAS 9EB112A1
5354333136303032334153202020202020202020
ST3160023AS 9EB112A1
Имеем seagate barracuda st340016a - bios находит без проблем, дальше после старта паркуется
