07 - ето магическая цифра(биты) - она же 0х07, она же 00000111b
ее пишут в нужный порт чтобы компутер "уснул" т.е. ушел в S5
ЗЫ: для разных чипсетов она разная (и тем не менее у ICH6/7/8/9 она "7")
для S0-"0", S1-"1", S3-"5", S4-"6", S5-"7"
ACPI Rev3.0a:
7.3.4 System \_Sx states
All system states supported by the system must provide a package containing the DWORD value following format in the static Definition Block. The system states, known as S0–S5, are referenced namespace as \_S0–\_S5 and for clarity the short Sx names are used unless specifically referring named \_Sx object. For each Sx state, there is a defined system behavior.
Table 7-11 System State Package
Byte Byte Description
Length Offset
1 0 Value for PM1a_CNT.SLP_TYP register to enter this system state.
>Что означает 07, идущая за 12 - опкодом Package?
ACPI Rev3.0a:
Length Offset
