наиден след материал: YOUR PHONE IS DEAD(RED LIGHT
"YOUR PHONE IS DEAD(RED LIGHT BLINKING)
Do a GDFS Restore and that should help your phone turn back on. I hope you did a GDFS back up before. If you don't have one, then you will need to re-flash your phone with Setool2lite v1.11 by plugging the phone without the battery. Then holding the 2&5 numbers on your phone insert the battery. Make sure you have the .mbn, .fbn and the cda files for your phone in the correct places. when your done flashing the phone should turn on. If that does not help you will let me know.
Good luck.
Restore your GDFS here:
Open Setool.
Select yout phone model.
Put the gdfs(xxxxxxxxxxxxxx.bin) into the "MISC FILES".
Click in WRITE GDFS.
Connect your phone to PC pressing "C" (IF with "C" dont work try using "2+5")
Then wait the process!!"
Очень похоже что именно ето и накрылось медным тазиком...
теперь вопрос след: у меня были записаны телефоны, фотки в память самого аппарата - я их потерял ? или же их можно как то вытащить?
