Как понять нашел патчер скрытые настройки или нет? Вот
Вот что выдал патчер:
BIOS Patcher ver. 4.23.
Found 4Mbit BIOS!
1. New CPU Support : not found.
2. P3-detect error : not found.
3. New Koeffs Support : not found.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : Warning! Not found "genu"!
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: not found.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
cbrom.exe V1.82 [04/11/07] (C)Phoenix Technologies 2001-2007
[CPUCODE] ROM is release
Adding modul.tmp 17.6%
Adding start.tmp 87.5%
Adding cpucode.bin 55.9%
(c)2002-2003 apple_rom, www.ROM.by
