проверил только на патчере 4.23 BIOS Patcher ver.
BIOS Patcher ver. 4.23.
Found 2Mbit BIOS (6.x)!
Found AMD K7-BIOS/platform!
1. New CPU Support           : -> fixed.
1a.Bus Disconnect Support    : -> fixed.
2. XP frequency              : -> fixed.
3. New Koeffs Support        : is not needed to be fixed.
4. 32Gb-problem              : not found.
5. Some HDD detect-problem   : not found.
6. "MB"/"GB" string search   : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x  : not found.
11.New Stepping Support      : is not needed to be fixed.
12.Tualatin L2-init error    : not found.
13.New Freq in Setup open    : found, but Unknown format!
Add new freq in BIOS Setup: 100/33Mhz 105/35Mhz 108/36Mhz 110/37Mhz 115/38Mhz 120/30Mhz 124/31Mhz 133/33Mhz 138/34Mhz 140/35Mhz 144/36Mhz 147/37Mhz 150/38Mhz 154/39Mhz 166/33Mhz
14.Set "Y" as default on exit: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp  41.7%
Adding start.tmp  87.5%
(c)2002-2003 apple_rom, www.ROM.by
вроде всё в порядке
в папку с патчером бросил
P4_MICRO.COD
P23MICRO.COD
REALL.COD
вот лог 6.15А
BIOS Patcher ver. 6.00.alpha_15. |for Award/Phoenix & AMI bioses|
Found 2Mbit Award BIOS (6.x)!
Adding AMDK7NOW! support     : -> fixed.
Add new freq in BIOS Setup: 100/33Mhz>105/35Mhz>108/36Mhz>110/37Mhz>115/38Mhz>120/30Mhz>124/31Mhz>133/33Mhz>138/34Mhz>140/35Mhz>144/36Mhz>147/37Mhz>150/38Mhz>154/39Mhz>166/33Mhz>
Tweak options addinng:
Display Features adding      : -> fixed.
Adding modul.tmp  39.8%
Adding tweak.tmp  45.2%
(c)2002-2004 apple_rom, www.ROM.by
(c)2006 Angel07, www.cgi-scripts.info
Вот лог BIOSINFOTOOL на ориг. файл:
 ────────────────────────────────────────────────────[compiled@15.03.2004]───
  BIOS Info Tool v1.3,          Copyright(c) 2004 by Serge Galkin (StarGaz0r)
  Win9x/Win2k/XP version                              e-mail:
 ■ ROM BIOS by Award Software International Inc., award.com/
   BIOS ID Strings: 07/19/2002-VT8366-8233-6A6LVM49C-00, 6A6LVM49
   Model: Award Modular BIOS v6.00PG (Medallion BIOS), 07/19/02
   Vendor: Micro-Star International Co. Ltd.
   Version String: W6380F1 V3.0 071902
   Designed for: VIA KT266(A) | KT333(A)
   Peripheral bus(es): ISA/PCI
 ■ BIOS update interface: awdflash hook
    [√] Supported Flash ROM Size: 2 Mbit
    [√] Flash Chip Block(s) Size: 16KBx8KBx8KB
    [√] NT Flash Support
 ■ Supported features:
    [√] VT8366 ACPI 0.9/1.x
    [√] PCI IRQ Routing Table v1.0 (correct)
    [√] Trend ChipAwayVirus(R)
    [√] EL TORITO CD-ROM Boot Specification
 ■ Award Decompression BIOS structure:
 No. Item-Name         Original-Size    Compressed-Size   Original-File-Name
 0   System BIOS       20000h (128K)    1305Ah (76,09K)   6A6LVM49.BIN
 1   XGROUP CODE       E610h  (57,52K)  9EFBh  (39,75K)   awardext.rom
 2   ACPI table        38D2h  (14,21K)  1657h  (5,58K)    ACPITBL.BIN
 3   GROUP ROM[0]      1DC0h  (7,44K)   EE1h   (3,72K)    _EN_CODE.BIN
 4   VRS ROM           2274h  (8,61K)   14ACh  (5,17K)    ANTI_VIR.BIN
 6   PCI driver[A]     10000h (64K)     9D14h  (39,27K)   FTLTMB24.bin
     (Promise Tech Inc PDC20265 FastTrak100 Lite EIDE Controller BIOS)
LOGO.jpg 23.24 КБ
