AP1250M/H is a linear regulator designed as a cost-effective solution for active
termination of DDR SDRAM. The converting voltage range is from 1.6V to 6V into a
desired output voltage, which is adjusted by two external resistors. The current
sourcing and sinking capability of the regulator is up to 1.5A/3A while the output
voltage within 2%/3%.
