Hidden
да тот же nvflash с ключиком -b
NVIDIA Flash ROM utility v03.15 Example of use: NVFLASH -s4 -fBIOS.ROM -l -f Flash the ROM using , then do compare and ~CRC32. Same as -f, but forces confirmation. -b Read ROM and save to . -k Read ROM and compare with . -x Xfer TV data from file to AT29LV512; SST29LE/VE512 SST39VF512. -v Display file version and ~CRC32 (if no filename, acts on ROM). -t Display 256 bytes of ROM, at offset C000h -e Erase the ROM. -d Display 256 bytes of ROM, at offset 0. -c Check for supported EEPROM. -l Don't light keyboard LEDs. -p Don't pause if ROMfile & chip PCI VenID, DevID mismatch. -u Don't pause if ROMfile & chip PCI subsystem ID mismatch. -h Reboot the PC after other tasks completed. -w Write protect ROM (only works on some ROMs). -r Remove ROM Write protect. (only works on some ROMs). -a List all supported device indexes. -m Enable Macintosh (FCode) compatible mode. -g Force a specific device index. -i Force specific device instance (use with -g). -? Display this screen. -s# Silence level: default All progress messages, all beeps. #=1 No progress messages, no beeps. #=2 No progress messages, no progress beeps. #=3 No progress messages. #=4 No progress beeps. #=5 No beeps. NVFLASH supports these EEPROMs: SST 29EE512 64Kx8 5.0V, 128B page, 0k blk, Man,Dev=(BF,5D) SST 29LE/VE512 64Kx8 2.9,2.7V, 128B page, 0k blk, Man,Dev=(BF,3D) SST 29EE010 128Kx8 5.0V, 128B page, 0k blk, Man,Dev=(BF,07) SST 29LE/VE010 128Kx8 2.9,2.7V, 128B page, 0k blk, Man,Dev=(BF,08) SST 39VF512 64Kx8 2.7-3.6V, 1B page, 4k blk, Man,Dev=(BF,D4) SST 39VF010 128Kx8 2.7-3.6V, 1B page, 4k blk, Man,Dev=(BF,D5) SST 39SF010 128Kx8 5.0V, 1B page, 4k blk, Man,Dev=(BF,B5) Atmel 29C512 64Kx8 5.0V, 128B page, 0k blk, Man,Dev=(1F,5D) Atmel 29C010A 128Kx8 5.0V, 128B page, 0k blk, Man,Dev=(1F,D5) Atmel 29LV512 64Kx8 3.0V, 128B page, 0k blk, Man,Dev=(1F,3D) Atmel 29LV/BV010A 128Kx8 3.0V, 128B page, 0k blk, Man,Dev=(1F,35) Atmel 49F512 64Kx8 5.0,3.0,2.7V, 1B page, 0k blk, Man,Dev=(1F,03) Atmel 49F001 128Kx8 5.0V, 1B page, 0k blk, Man,Dev=(1F,05) Atmel 49F001T 128Kx8 5.0V, 1B page, 0k blk, Man,Dev=(1F,04) Atmel 49F010 128Kx8 5.0V, 1B page, 0k blk, Man,Dev=(1F,87) Atmel 49(H)BV/LV01 128Kx8 2.7-3.6V, 1B page, 0k blk, Man,Dev=(1F,17) AMD 29LV010 128Kx8 2.7vV, 1B page, 16k blk, Man,Dev=(01,6E) AMD 29LV001T 128Kx8 2.7vV, 1B page, 16k blk, Man,Dev=(01,ED) AMD 29LV001B 128Kx8 2.7vV, 1B page, 16k blk, Man,Dev=(01,6D) MX 29F001T 128Kx8 5.0V, 1B page, 0k blk, Man,Dev=(C2,18) MX 29F001B 128Kx8 5.0V, 1B page, 0k blk, Man,Dev=(C2,19) ST M29W512B 64Kx8 2.7-3.6V, 1B page, 0k blk, Man,Dev=(20,27) WBond W29EE512 64Kx8 5.0V, 128B page, 0k blk, Man,Dev=(DA,C8)
Hidden
