Проверяйте вывод WP# - When low, prevents programming or block erase to all but the highest addressable block (0-6 in a 4-Mbit, 0-14 in an 8-Mbit component), regardless of the state of the corresponding lock registers. WP#-high disables hardware write protection for these blocks, though register-based protection still applies. The status of TBL# does not affect the status of block-locking registers.
И еще вывод VPP - For erasing array blocks or programming data. VPP = 3.3 V or 12 V VPP. With VPP ≤ VPPLK, memory contents cannot be altered. Attempting a block erase or program with an invalid VPP (see DC Characteristics) will produce spurious results and should not be attempted. VPP may only be held at 12 V for 80 hours over the lifetime of the device.
Я ж вот сделал ХАБ для ВИЛЕПРОМА
Выражайтесь все таки общепринятыми терминами - вы сделали переходник LPC/FWH-->DIP32.
