Автор: valera537 , 28 ноября 2013
BIOS Date: 01/14/10
BIOS Type: American Megatrends
BIOS ID: 64-0100-009999-00101111-011410-Eaglelake-1AEGM002
OEM Sign-On: BIOS Version: P01-A1L
Release
Chipset: Intel 2E30 rev 3
Superio: Unknown
OS: WinXP SP3
CPU: Intel(R) Celeron(R) CPU 450 @ 2.20G 2200 Mhz MAX: 2200 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: Unknown
Memory Installed: 1024 MB
Memory Maximum: 4096 MB
Memory Slot 01: 1024 MB
Memory Slot 02: 0 MB
ACPI Revision: Unknown
ACER G41T-AM REV:1.0 motherboard Gateway iXtreme M3730 Intel G41 LGA 775 DDR3
Feature Specification:
CPU
Processor Support Socket LGA775, Intel Core 2 Duo Quad, Core 2 Dual-Core, Pentium Dual-core, Celeron.
FSB Max 1333/1066/800 MHz.
Chipset
North Bridge – Intel G41
South Bridge – ICH7
Integrated Graphics
Intel GMA X4500
Memory
2 * 240-pin DDR3 DIMM slots Supports Dual Channel DDR3 1333/1066 MHz non-ECC , un-buffered memory (Max 4GB)
Expansion Slots
1* PCI Express x16
2 * PCI Express x1
1 * PCI
Storage
4 * SATAII 3Gb/s connectors
Supports HDDs, Internal Solid State Drive (SSD)
Audio
Realtek ALC662 – High Definition
Ethernet
Integrated Gigabit – 10/100/1000Mb/s
USB
Embedded 4 * USB 2.0
2 x USB 2.0 connectors (2 ports) Total 8 USB ports
Rear Panel
1 x VGA
1 x Audio I/O
1 x RJ45 Ethernet/LAN
1 x PS/2 green color for mouse
1 x PS/2 purple color for keyboard
2 x USB 2.0
Internal
2 * USB headers for 4 USB ports
1 * 4-pin CPU Fan connector
1 * 3-pin Rear Fan connector
1 * 4-pin ATX 12V Power connector
1 * 24-pin ATX Power connector
1 * Front Audio header
1 * Front Panel header
BIOS
Flash BIOS
Form Factor
Micro-ATX
guar33
12 лет 12 месяцев назад
судя с сылки http://goods.ruten.com.tw/item/show?21303280322927
это http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=2064 но не уверен
старый биос сохраните
и шить P01-A1L
[OFF]
и шить P01-A1L
:D [/OFF]
