Автор: Selim , 10 февраля 2013
Здравствуйте.
Принесли после неудачной прошивки два вышеуказанных предмета.
3310
При включении горят все знаки, ЭКО, ошибка и замятие.
Шили чем неизвестно.
Я шил и 25 и 33. Оригинальные, и фикс.
Результат один и тот же.
Лог.
Reset Target and Run Flash Writing Program Again
Boot&Mon. CheckSum OK!
[SFLASH_InitFLASH][NG]
[ WATCH DOG RESET Booting... ]
Press any key to execute Monitor Program within 1 sec...
Kernel Data Read Start From Serial Flash
Kernel Data Read End
New kernel was found...
CHKSUM
check sum start address : 42000000, count : 002A0000
check sum : 0000FDFE
} /* Checksum End
Checksum Fail!!, original checksum = 0x0000A5A5, checksum = 0x0000FDFE
CHKSUM
check sum start address : 40060000, count : 00015FFE
check sum : 0000A5A5
} /* Checksum End
Checksum OK!!
finish copy image to the RAM
===> Now program restarted on the RAM to program flash
jump to 0x40060000
Flash Data Download Address : 0x43000000
Start flash_writer
verify_Image : 0x43000000
i_header->pul_start_addr : 0x00000000
i_header->ul_count : 0x00000000
model : 0x00000000
flash type : 0x00000000
image type : 0x00000000
temp_buf :
SIG : $IMG
Can not find sig
----------- Display Dcache Status ------------
Control register = 0x000510F8
Icahe : ON
Dcahe : OFF
MMU : OFF
Download Image from PC
Ready to download from Parallel/Usb/Serial (0x43000000)
Samsung OTG, 2006
Link ID : [4F54260A]
Drv "design ware core" USB download
Image includes PJL(0000001B) -> Waste 80 bytes
[[7864424 Bytes received]] - Complete Downloading
} /* Download End */
i_header->ul_count : 0x00780000
model : 0x03000042
flash type : 0x00010002
temp_buf : $IMG
SIG : $IMG
FlashCheckSum
check sum start address : 43000018, count : 00780000
} /* Checksum End
Source Checksum is valid
Boot image!
Version : -17
This is not a valid image.!!!!
Downloaded Image is not Valid
CHKSUM
} /* Checksum End
CHKSUM
} /* Checksum End
Checksum OK!!
jump to 0x40060000
Start flash_writer
model : 0x00000000
temp_buf :
SIG : $IMG
Can not find sig
Icahe : ON
Dcahe : OFF
MMU : OFF
Samsung OTG, 2006
Drv "design ware core" USB download<0>
[ POWER ON Booting... ]
CHKSUM
} /* Checksum End
CHKSUM
} /* Checksum End
Checksum OK!!
jump to 0x40060000
Start flash_writer
model : 0x00000000
temp_buf :
SIG : $IMG
Can not find sig
Icahe : ON
Dcahe : OFF
MMU : OFF
Samsung OTG, 2006
На обоих присутствует ошибка "original checksum = 0x0000A5A5".
Прошивки оригинальные и проверенные на других аппаратах.
Подскажите кто знает в чем проблема, и какие пути ее решения.
Перенес в Ремонт принтеров, ксероксов, факсов и т.п.
13 лет 1 месяц назад
БП - переводится как блок питания.
