Автор: NMD , 10 ноября 2007
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
15 лет 10 месяцев назад
Ток, напряжение, сопротивление Rds. Остальное для БП не очень существенно.
Чем из следующих можно заменить FQP 2N60? И кто из них будет полным или отдаленным аналогом?
D30SC4M
MJE13009L
D13007
MBR2045CT
L7805CV
76121P
SBL3040PT
SF1004G
STPR1020CT
F16C20C
C3150
STP2045CT
NDS40-20
C4160
C5027
F12C20C
KIA 7805P
SBL2040CT
STPR1020CT
C3866
STD13007
45N03LT
E13007
J13007
makarog
Alexandr027, вы бы хоть какую-то документацию почитали бы на приведенный список, чтоб глупости не спрашивать (у вас в одной куче мосфеты, биполярные, диоды и интегральные стабилизаторы)
Я все перечислил, что есть. А вы не удосужились даже привести хотябы один аналог или сказать что его нет.
D30SC4M
MJE13009L - мощный биполярник в основной
D13007 - биполярник в основной
MBR2045CT - сдвоенный диод Шоттки
L7805CV - стабилизатор 5в
76121P
SBL3040PT - сдвоенный диод Шоттки
SF1004G - Шоттки?
STPR1020CT - сдвоенный диод Шоттки
F16C20C - Шоттки?
C3150
STP2045CT - сдвоенный диод Шоттки
NDS40-20
C4160 - слабенький биполярник в основной
C5027 - биполярный в дежурку
F12C20C
KIA 7805P - стабилизатор 5в
SBL2040CT - сдвоенный диод Шоттки
C3866 - биполярный в дежурку
STD13007 - биполярник в основной
45N03LT - Полевик?
E13007 - биполярник в основной
J13007 - биполярник в основной
полные аналоги от разных производителей:
все с маркировкой 7805
все 13007
Писал по памяти, мог допустить ошибку. Остальные не помню - ищи datasheet
Тот, который ты хочешь заменить - полевой 2А 600В. Можно менять на 4N60 (4А) 6N60 (6А), но они дороже.
Его нет.
Если Вы не удосужились разобраться, как работает дежурка, то нет никакого смысла называть аналог. Кроме замены самого транзистора обычно требуются еще некоторое осмысление неисправности для устранения источника проблемы, которое невозможно без знания элементной базы.
vatan
15 лет 9 месяцев назад
Привет!
Не могу найти дата шиит на С5679.
БП DTK, плата Macron Power 300 W.
ШИМ 494, дежурка С5027.
С5679 - ключевые транзисторы (какойто китайский шит)
попробую 13007
Дубли удалил
doomnik
Какой-то левый китаец. FUJI
Какая мощность блока, какой ШИМ, где стоит транзистор, в каком корпусе?
Почти наверняка MJE13007- 13009 будет надежнее.
alphan100
БП DTK, плата Macron Power.
типа вашего БП ( вроде такие же С5679 на PowerMan HPC-300-102 CE )
https://rom.by/forum/Pomogite_opredelit_defekt_Power_Man_HPC-300-102CE_mozhet
у этого ТС стояли два с4106 на 1 радиатора
с4106 -> аналог 13007\13009 ( только слабее)
vatan
Еще два вопроса для специалистов на примере 300W БП:
1. До какой степени можно нагрузить БП без вентилятора? напр. до 50 W?
2. Возможно ли поставить ключи и выпрямители на радиатор снаружы? длина проводников скажем до 6-8 см. Как будут помехи?
