Автор: NMD , 10 ноября 2007
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
vlsm (не проверено)
15 лет 11 месяцев назад
Люди добрые помогите кто чем может!!! БП ВМ два транзистора (маркировка) D 2144 К2632 Ни параметров ничего Второй день в инете ищю голову сломал.
Rom
http://www.alldatasheet.com/view.jsp?Searchword=D2144
http://www.alldatasheet.com/datasheet-pdf/pdf/95842/SANYO/2SK2632LS.html
Luugin
15 лет 10 месяцев назад
Заменил 4242 на то что было (С2335). Но БП не запускается...
Может ли причина крыться в том, что у 4242 Ib=2A, у С2335 Ib=3,5A? Так сказать не хватает тока для открытия?
(+5SB) имеется.
Не думаю. Тем более без нагрузки.
Подскажите чем вообще можно заменить SSP 2N60B
Из:
E13007-1
E13007-2
J13007-2
D13007
STD13007
C5027-R
2SC4106
STPS2045CT
STPR1020CT
SSS2N60B
2SC3866
2SC5353
И какие из них взаимозаменяемые?
Только на SSS2N60B
Взаимозаменяемые
E13007-1
E13007-2
J13007-2
D13007
STD13007
2SC4106 можно заменить на MJE13007
Взаимозаменяемые
KSC5027-R
2SC5353
2SC3866
STPS2045CT и STPR1020CT сдвоенные диоды на 45 и 200 вольт. 20 и 10 ампер
Dnepr1000
Здравствуйте,прошу "бывалых спецов" поделиться соображениями вот по какому моменту: почитав форум,помимо многих полезных моментов понял следующее-особенности принципа работы БП позволяют использовать в качестве ключевых транзисторов преобразователя как биполярные так и полевые транзисторы,практически без изменения обвязки. То есть-если БП (мощные ключи)был собран на биполярных-можно ставить полевики и наоборот. Если это действительно так-каковы основные критерии при подборе замены? То что напряжение (ток) должно быть рабочее не меньше-это понятно-возможно есть ещё некоторые немаловажные параметры? На что обращать внимание? Спасибо.
Не совсем. Принцип работы у транзисторов разный. Биполярные открываются током, а полевые напряжением. Биполярному достаточно 5 вольт для открытия, а полевому лучше >10в, но ни в коем случае больше 18в.
alphan100
SSS2N60B можно на 4N60 менять спокойно
иногда 4N60 в магазинах есть, а 2N60 нет.
Dnepr1000
Поиски 2SK2765 на замену пробитой паре аналогичных ни к чему не привели-зато нашёл замену по току и по напряжению, также по расс. мощности. Однако смущает вот какой момент: в кратком описании мощного полевого транзистора в каталоге магазина-есть такие аббревиатуры-(HS SW) и (HS PSW)-подскажите пожалуйста кто в курсе-что значат эти аббревиатуры и взаимозаменяемы ли транзисторы с такими аббревиатурами в обозначениях. Вот сайт,где это я нашёл http://www.radioman.com.ua/ нажать ссылку "полевые транзисторы".
Cпасибо.
