Автор: UAM , 5 октября 2011
Мигнул свет. Аккумуляторы в UPS не выдержали и Subj начал циклически перезагружаться...
Base ethernet MAC Address: 00:0e:84:03:41:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 128 files, 5 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 5406208
flashfs[0]: Bytes available: 10592768
flashfs[0]: flashfs fsck took 8 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:c2970-i6l2-mz.121.14-EA1a/c2970-i6l2-mz.121.14-EA1a.bin"...@@@@@@
File "flash:c2970-i6l2-mz.121.14-EA1a/c2970-i6l2-mz.121.14-EA1a.bin" uncompresse
d and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco Internetwork Operating System Software
IOS (tm) C2970 Software (C2970-I6L2-M), Version 12.1(14)EA1a, RELEASE SOFTWARE (
fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 02-Sep-03 02:23 by antonino
Image text-base: 0x00003000, data-base: 0x00681E70
Initializing flashfs...
flashfs[1]: 128 files, 5 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 5406208
flashfs[1]: Bytes available: 10592768
flashfs[1]: flashfs fsck took 8 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Waiting for Port download...Complete
cisco WS-C2970G-24TS-E (PowerPC405) processor (revision B0) with 118774K/12288K
bytes of memory.
Processor board ID CSG0750P05H
Last reset from power-on
1 Virtual Ethernet/IEEE 802.3 interface(s)
28 Gigabit Ethernet/IEEE 802.3 interface(s)
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:0E:84:03:41:80
Motherboard assembly number : 73-9095-03
Power supply part number : 341-0045-01
Motherboard serial number : CAT0749098U
Power supply serial number : LIT074500WK
Model revision number : B0
Motherboard revision number : A0
Model number : WS-C2970G-24TS-E
System serial number : CSG0750P05H
Top Assembly Part Number : 800-24261-01
Top Assembly Revision Number : B0
Switch Ports Model SW Version SW Image
* 1 28 WS-C2970G-24TS-E 12.1(14)EA1a C2970-I6L2-M
Press RETURN to get started!
Unexpected exception to CPU vector 2000, PC = 262E9C
-Traceback= 262E9C 262CC0 260308 25E564 25E72C 1CACD0
=== Flushing messages (02:01:28 UTC Mon Mar 1 1993) ===
Buffered messages:
00:01:21: %STACKMGR-6-SWITCH_ADDED: Switch 1 has been ADDED to the stack
00:01:23: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:01:26: %SYS-5-CONFIG_I: Configured from memory by console
00:01:26: %SYS-5-RESTART: System restarted --
fc1)
Queued messages:
00:01:128860398532: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console deb
ugging output.
fc1)
fc1)
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x001B9430 SRR1 = 0x00029210 SRR2 = 0x0028DB08 SRR3 = 0x00021000
ESR = 0x00000000 DEAR = 0x00000000 TSR = 0x8C000000 DBSR = 0x01000000
CPU Register Context:
Vector = 0x00002000 PC = 0x00262E9C MSR = 0x00029210 CR = 0x53300000
LR = 0x00262E94 CTR = 0x002CD884 XER = 0xC0000040
R0 = 0x00262E94 R1 = 0x0156C868 R2 = 0x00000000 R3 = 0x0A0F0013
R4 = 0x011B76EC R5 = 0x00000001 R6 = 0x00000000 R7 = 0x00000000
R8 = 0x0A0F0008 R9 = 0x0A0F0000 R10 = 0x00000000 R11 = 0x011B63B8
R12 = 0x33300000 R13 = 0x00010000 R14 = 0x00000000 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000008
R24 = 0x012281E0 R25 = 0x00000240 R26 = 0x00000000 R27 = 0x00000002
R28 = 0x00000000 R29 = 0x0A0F0013 R30 = 0x0A0F0008 R31 = 0x07A1DA74
Stack trace:
PC = 0x00262E9C, SP = 0x0156C868
Frame 00: SP = 0x0156C898 PC = 0x00262E94
Frame 01: SP = 0x0156C8C0 PC = 0x00262CC0
Frame 02: SP = 0x0156C8E0 PC = 0x00260308
Frame 03: SP = 0x0156C900 PC = 0x0025E564
Frame 04: SP = 0x0156C928 PC = 0x0025E72C
Frame 05: SP = 0x00000000 PC = 0x001CACD0
C2970-S uptime is 1 minute, 33 seconds
bytes of memory.
Залез внутрь, заменил 5 дутых конденсаторов, но дефект не изменился. Какие рекомендации?
Если залить новый IOS, то как это сделать и как определить по названию файла, что есть в этой конфигурации?
ivp
15 лет 1 месяц назад
Рекомендация одна (если все больное перепаяно) - перешить. Лучше программатором, ежели есть (или можно поковыряться хот-свапом). Версию прошивки взять последнюю. Примерно так.
ЗЫ: Там все очень просто определяется (касательно содержимого прошивки) - надо немного напрячь мозги, сопоставить даты и описания изменений.
Собственно, не знаю, что может быть больное. Краем уха слышал, что у Cisco попадались бракованные SMD конденсаторы. Второй такой железки нет да и вряд-ли кто-то даст над ней издеваться.
Версию скачал, но в IOS не входит, а в загрузчике не нашел, как шиться.
Собственно, вопрос перешел уже в спортивную сферу. Поставили 3750.
Зы. Напряг, разобрался.
Aleexis
14 лет 5 месяцев назад
в 29ой вроде кондёров не много - заменить все электролиты, температурный режим из-за проца там нехороший.
Если была гроза, уже сколько раз попадался народ - думал проц... оказывался кварц, начинает врать, начинают врать таймеры - задачи в разных местах виснут, правда у вас более похоже на что-то другого характера.
Вам-бы спросить на nag.ru , там опытных cisco-вщиков практикующих достаточно много!
14 лет 10 месяцев назад
Гроза была, но за несколько месяцев до выключения. Старых логов нет.
Тоже подумывал на прошивку.
Собственно, сейчас еще не актуально. Железка ждет списания и уничтожения. Вот после этого.... Если бловеры не утянут....
