By Pinczakko , 28 May 2004
Я имею доработать мою биозу путем заменять ть procedure" "EPA; включить IOQ уровня 4 для VIA693ЈA (Iwill VD133 -- motherboard шлица PIII/II 1). I'm смотря для другого более лучшего метода, но не путем использование rom ISA, я знаю эту выходку. Огорченно, я не знаю русского, I'm использующ babelfish для этого перевода.
Вы
  • No HTML tags allowed.
ivp
22 years 6 months ago
2Pinczakko
Speak English, plz, Your automatic translation is not uderstandable...
sorry, I thought everyone here is speaking russian :( . I've modify my old mainboard BIOS (Iwill VD133 -- PIII/II) which uses via 693A/596B, by replacing the EPA procedure ,and couple of years ago by using ISA rom. This mod is to enable IOQ (In Order Queue Depth) of 4 level and to enable 4 bank DRAM Interleaving (sorry if I'm wrong spelling it :) ). You can see my article about it http://www.geocities.com/mamanzip/. I'm lookign forward a better method, what I've done is basically a "brute force" method. I saw you guys here are more advanced, I need your advice. Thank you :D
ivp
Thanks for Your article, I'll read it with big interest...
For BIOS modding try to use current releaze of BIOS_Patcher by apple_rom (English Readme with BPatcher description and manual is in archive folder); in the same folder with Patcher MUST be CBROM (v.2.07 only!!!), LHA and Real_Processor_Codes...
Be careful, plz, pay attention to read about the syntax and keys, and do two versions of BIOS file - with and without "undo" mode; flash first of them first ( :wink: ), then, only if the mobo will start and the logo www.rom.by will appear, flash second...
If You will need to set "undo" mode, press the "-" button at system start up (works not at all cases) or disconnect the keyboard before the mobo starts (note: the USB-keyboard = "undo"!)...
And one more - if BPatcher will write in log to flash with boot-block - flash only with it; if will write that new FSB meanings founded and fixed - unlock them with Modbin (and don't forget to correct CRC with CBROM - release/add something in BIOS file - after working with Modbin)...
Good luck! :lol:
PS: Everyone here speaks Russian, but sometime... :wink:
Thank you. I'll learn russian somehow, I'm currently able to speak 5 languages, I hope it shouldn't be a big problem :D. Russian speaking countries are more advanced than the english speaking country in things like this. I have to admit so, because this is the fact. Thanks a lot :D.
BTW, is this bios patcher program is open source ? if it is so, where can I download the source code ? Thx :D.
ivp
You see, here are some smart guys who don't beleve Intel that "more and more MHz" (and more and more money :wink: ) are needed; and some of that guys have no this "more and more money" (that is additional reason to be smart :lol: )...
And about BPatcher source code You need to talk with apple_rom, IMHO, by private message or mail k6-2@narod.ru ...
I agree with you :D. I've been crawling over the net for several years to find a community that think the way I also think. Finally after few frustrating years, I found it here, I'll learn russian as fast as I can so that I can help in your development and "research" guys. I like this style of development, I will share all the resources I have to you. I know most of you are more knowledgeable than me, so, pardon me if that disturbs you :oops: . Thx a lot
ivp
...I'll learn russian as fast as I can...
Good luck once again... :mrgreen:
PS: Something for Your profile: the correct name of Your country in Russian is "Индонезия"; and the right translation for Your tagline is: "Знания людей принадлежат миру" (let's begin Your Russian lessons right now :wink: )...
Pardon me :(, what do I need to type the cyrillic alphabet which you are using here? I only have USA type keyboard. Do you guys using dvorak keyboard or something else to type it ?
ivp
We use special latin/cyrillic keyboards...
There are some free-ware automatic latin/cyrillic transliterators, AFAIC, try to find one...
