By Anonymous (not verified) , 5 February 2006
лог сабжа до лечения.
[code:1]Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M.14 01-16-03 11:51
Buzz - Head Mask 000F - Switch to full int.
Spin Ready
3.06 08-08-03 14:41
(P)PATA Reset
CE Log EC=0 Rtype=36 OV=0 STStatus0
Master[/code:1]
лог запуска н2.
[code:1]T>N2,,22
Begin Test 02
Cert Table loaded
ASCII logging on
Not Power Cycling
Not Power Cycling
Zone 00 Head 00 adaptives set to defaults
Zone 0F Head 03 adaptives set to defaults
Preamp Sent Greater than Max Allowed Bias (0B-09)
Head Mask 000F -
Read Bias - Head 0 1 2 3
B B B B
HiTemp Bias Head 0 1 2 3
B B B B
P[/code:1]
лог после передергивания питалова
[code:1]nterface task reset
Spin Ready
3.06 08-08-03 14:41
(P)PATA Reset
AutoRd Err 43 at 00f6b8.00.0000
AutoRd Err 47 at 00f6b8.00.0140
OVERLAY FAILED(
T>CurrentCHS=0000/0/00 MltSiz=00 DMAMod=00
((AutoRd Err 43 at 00f6b7.00.0000
INVALID Cert Disk Code - ROM Resident Revision Required: 3.06
2>H
Head 0
2>H
Head 1
2>H
Head 2
2>H
Head 3
[/code:1]
как побороть? поговаривают надо поправить занчение в памяти.
Добавлено спустя 1 день 10 часов 22 минуты 27 секунд:
никто не знает или все молчат? :(
  • No HTML tags allowed.
Mar.S.
20 years 9 months ago
Стартуй селфскан из полного сейфа, если имеешь протокол sdld. Если нет, то используй как вариант хотсвап.
gold55
продолжение истории....
[code:1]Begin Test 02
Cert Table loaded
ASCII logging on
$Switch to full int.
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
Not Power Cycling
AM Reacquired
AM Reacquired
Not Power Cycling
Zone 00 Head 01 adaptives set to defaults
Zone 00 Head 02 adaptives set to defaults
Zone 01 Head 00 adaptives set to defaults
Zone 01 Head 01 adaptives set to defaults
Zone 01 Head 02 adaptives set to defaults
Zone 02 Head 00 adaptives set to defaults
Zone 02 Head 01 adaptives set to defaults
Zone 02 Head 02 adaptives set to defaults
Zone 03 Head 00 adaptives set to defaults
Zone 03 Head 01 adaptives set to defaults
Zone 03 Head 02 adaptives set to defaults
Zone 04 Head 00 adaptives set to defaults
Zone 04 Head 01 adaptives set to defaults
Zone 04 Head 02 adaptives set to defaults
Zone 05 Head 00 adaptives set to defaults
Zone 05 Head 01 adaptives set to defaults
Zone 05 Head 02 adaptives set to defaults
Zone 06 Head 00 adaptives set to defaults
Zone 06 Head 01 adaptives set to defaults
Zone 06 Head 02 adaptives set to defaults
Zone 07 Head 00 adaptives set to defaults
Zone 07 Head 01 adaptives set to defaults
Zone 07 Head 02 adaptives set to defaults
Zone 08 Head 00 adaptives set to defaults
Zone 08 Head 01 adaptives set to defaults
Zone 08 Head 02 adaptives set to defaults
Zone 09 Head 00 adaptives set to defaults
Zone 09 Head 01 adaptives set to defaults
Zone 09 Head 02 adaptives set to defaults
Zone 0A Head 00 adaptives set to defaults
Zone 0A Head 01 adaptives set to defaults
Zone 0A Head 02 adaptives set to defaults
Zone 0B Head 00 adaptives set to defaults
Zone 0B Head 01 adaptives set to defaults
Zone 0B Head 02 adaptives set to defaults
Zone 0C Head 00 adaptives set to defaults
Zone 0C Head 01 adaptives set to defaults
Zone 0C Head 02 adaptives set to defaults
Zone 0D Head 00 adaptives set to defaults
Zone 0D Head 01 adaptives set to defaults
Zone 0D Head 02 adaptives set to defaults
Zone 0E Head 00 adaptives set to defaults
Zone 0E Head 01 adaptives set to defaults
Zone 0E Head 02 adaptives set to defaults
Zone 0F Head 00 adaptives set to defaults
Zone 0F Head 01 adaptives set to defaults
Zone 0F Head 02 adaptives set to defaults
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
Head Mask 0000 -
B B B
B B B
Head Mask 0000 - Switch to full int.
Spin Ready
Ref Trk Tan Timing Skew (h0 to h0) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h0) = 0000 servo clocks.
Ref Trk Tan Timing Skew (h0 to h1) = 1D8B servo clocks.
ID-OD Delta Timing Skew (h0 to h1) = FFF8 servo clocks.
Ref Trk Tan Timing Skew (h0 to h2) = 0003 servo clocks.
ID-OD Delta Timing Skew (h0 to h2) = 0EC4 servo clocks.
Ref Trk Tan Timing Skew (h0 to h3) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h3) = 0000 servo clocks.
Calibrating Physical Track 0 on heads 0 thru 2
Calibrating Head 0 ...
GC Seek Error 2 !!!
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
AbEnd Test 02
[/code:1]
[code:1]2>H
AM Reacquired
Head 0
2>H
Head 1
2>H
AM Reacquired
Head 2
2>H
AM Reacquired
Head 0 [/code:1]
0 1 2 головы в отличном состоянии были до тестов. возможно данная трабла возникла из-за сброса адаптивов или еще чего то подобного. что скажут специалисты по данному сабжу.
