By ROMby Unknown , 11 August 2004
which version of bios should i patch?
i wanna connect an 80GB disk to a
FIC VA-503+ mobo (MVP3 chipset)
the latest official release bios supports
up to 40GB, the latest beta 65GB
so which one should i use?
and another question
an Acorp 6BX67 (440BX)
the MB has no switches to control
the FSB, the cpu is Celeron 400
if i disconect one of the slot connectors
it will be 600MHz and wont work
with the boxed cooler
i`ve downloaded the latest bios (1.4)
and bios patcher 4.23 w/ the tools
(lha, cdrom ...) from the links in rom.by,
patched, burned, but still there r no FSB
controls in the BIOS
is there anything else i can do to get say
75Mhz fsb?
TIA
  • No HTML tags allowed.
lich
22 years 3 months ago
по поводу версии биоса, можно патчить любую, а вот прошивать наверное стоит сначала бету :o , если в ее работе все устроит, то и заморачиватся дальше не стоит.
а вот по поводу 6BX67 вопрос:
процессор с переходником или без?
если с переходником, то шина на нем переставлятся может.
а вобще, возможно на ней шина определяется только автоматически..
посмотрю на работе.
DanZer
lich said, and I am just translating that there is no difference for the patcher is your bios file beta or release one. You may flash the beta one in original state, may be it'll work and there'll be no need for patching, if it'll satisfy you. If it will not - patch & flash the release one.
And about Acorp mobo - it's very likely there is no support for non-standart FSB freq in its bios, so patcher just can't made it open. So you have either to set your CPU running on 100MHz bus (probably it can't due to manufacturing technology limit), or change the mobo.
Or, install something like SoftFSB or CPUFSB and set FSB from Windows. But beware - modern HDDs do not like PCI overclocking and you may lose your data.
2 lich
Переходник, который может выставить 75 или 83 по шине? :shock: Первый раз про такое чудо слышу :lol:
ivp
Я так понимаю, что имелось в в виду переключение шины Auto/66/100/133 или Auto/66/100, обычно имеющееся на переходниках...
DanZer
Так было же написано, что на шине 100 у него кулер не справляется (хотя, имхо, все же камень не хочет гнаться) и потому хочет поставить 75 шину
75Mhz fsb?
lich
ivp, точно )
именно это и имел в виду. хотя помоему на некоторых есть возможность и другие ограничения на шину ставить, типа 75 шины, хотя , на свое счастье, в последнее время мать под проц подбирается), а не наоборот (слава богу, дожил )))
ivp
Кроме этих частот, никаких других на переходниках быть не может, по одной очень простой причине: ног, отвечающих за промежуточные частоты, нет и никогда не было, а переходник может управлять только тем, что меняется ногами, в том числе и переключением между опорными 66/100/133...
Anonymous (not verified)
ok, thx a lot
the CPU is slot 1
there is no переходник
(btw i can read russian :) )
i`m gonna try SoftFSB or CPUFSB now
