By ROMby Unknown , 22 July 2007
очень нужен биос для этой материнки
  • No HTML tags allowed.
Root
19 years 4 months ago
http://www.albatron.com.tw/English/Service/bios_index.asp?keywords=kx400&Submit=Search
Anonymous (not verified)
19 years 3 months ago
сайт не отвечает...
icbook
Сайт отвечает самым волшебным образом:
[code:1]KX400-8XV (V3.0) 0.23 MB R3.00 2003/11/21 Initial Release Version
KX400-8XV (V3.0) 0.23 MB R3.00a(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version)
KX400-8XV (V3.0) 0.23 MB R3.01 2004/9/24 Supports Sempron CPU
KX400-8XV Pro (V3.0) 0.23 MB R3.00 2003/11/21 Initial Release Version
KX400-8XV Pro (V3.0) 0.21 MB R1.02c(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version)
KX400-8XV Pro (V3.0) 0.23 MB R3.00a(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version)
KX400-8XV Pro (V3.0) 0.23 MB R3.01 2004/9/24 Supports Sempron CPU
KX400-8XV (V2.0) 0.22 MB R2.03 2003/9/3 Initial Release Version
( Support KX400-8XV / Pro Version 2.0 mainboard only)
KX400-8XV (V2.0) 0.22 MB R2.05 2003/10/23 1.Fixed hang C1 if set CPU ratio and FSB(100,133,166,200) at the same time.
KX400-8XV (V2.0) 0.22 MB R2.05a(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version)
KX400-8XV Pro (V2.0) 0.22 MB R2.03 2003/9/3 Initial Release Version
KX400-8XV Pro (V2.0) 0.22 MB R2.05 2003/10/23 1.Fixed hang C1 if set CPU ratio and FSB(100,133,166,200) at the same time.
KX400-8XV Pro (V2.0) 0.22 MB R2.05a(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version)
KX400-8XV Pro 0.21 MB R1.01 2003/8/27 Initial Release
KX400-8XV Pro 0.21 MB R1.01a( Beta ) 2003/10/2 Beta Version
1. Support Barton 3000+ ( FSB 333) CPU.
KX400-8XV Pro 0.21 MB R1.01b(Beta) 2003/10/2 Beta Version
1.support new Duron FSB = 266 (Applebred) CPU.
KX400-8XV Pro 0.22MB R1.02c (Beta) 2004/11/4 Support AMD Sempron CPU
KX400-8X 0.19 MB R1.01 2003/8/27 Initial Release
KX400-8X 0.18 MB R1.01e( Beta ) 2003/10/2 Beta Version
1. support 2600+ ( FSB333 MHz) CPU
KX400-8X 0.18 MB R1.03 2003/10/2 1. Support Athlon™XP 2600+ ( FSB 333) CPU.
2. Support Barton 2800+ ( FSB 333) CPU.
3. Fixed low speed FAN can't be detected.
KX400-8X 0.18 MB R1.05 2003/10/2 1. Improve ATI9700Pro stability.
2. Support Barton 3000+ ( FSB 333) CPU.
KX400-8X 0.18 MB R1.05b(Beta) 2003/10/2 Beta Version
1. support new Duron FSB = 266 (Applebred) CPU.
KX400-8X 0.18 MB R1.05c (Beta) 2004/11/4 Support AMD Sempron CPU
KX400-8XV 0.21 MB R1.01 2003/8/27 Initial Release
KX400-8XV 0.21 MB R1.01a( Beta ) 2003/10/2 Beta Version
KX400-8XV 0.21 MB R1.01b(Beta) 2003/10/2 Beta Version
KX400-8XV 0.21 MB R1.02c(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version)
KX400-8XV 0.22MB R1.02c (Beta) 2004/11/4 Support AMD Sempron CPU
KX400+ 0.19MB R1.01 2003/10/2 Initial Release
KX400+ 0.19MB R1.02 2003/10/3 1. Fixed system won't boot if held down "Insert" key before power on.
2. Fixed 98SE S3 resume fail if connect CDROM and enable CDROM DMA mode.
3.Added new item "Power Button Up" for Disable power button function if select PS2 keyboard wakeup.<
KX400+ 0.19 MB R1.04 2003/10/2 1. Fixed audio will disappear after restarting the OS
2. Fix USB2.0 device + USB hub cause USB2.0 device speed down to 1.1
3. Fixed "DDR:CPU Ratio" display error when FSB = 166( JP2 = 34)(only 2.00X)
4. Fixed "USB Controller" itemvalue display er
KX400+ 0.19 MB R1.04f(Beta) 2003/10/2 Beta Version
1. support Athlon™ XP 2600+ ( FSB333 MHz) CPU.
KX400+ 0.19 MB R1.05 2003/10/2 1. Support Athlon™ XP 2600+ (FSB 333) CPU
2. Support Barton 2800+ (FSB 333) CPU
3. Fixed low speed FAN cannot be detected
KX400+ 0.19 MB R1.06 2003/10/2 1. Support Barton 3000+ (FSB 333) CPU
KX400+ 0.19 MB R1.06a(Beta) 2003/10/2 Beta Version
KX400+ 0.19 MB R106b(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version)
KX400+ Pro 0.19MB R1.02 2003/10/2 Initial Release
KX400+ Pro 0.19 MB R1.03A( Beta) 2003/10/2 Beta Version
1.Fix Dip switch clock to 166 DDR ratio X 2
2.Fix clock 166 overclock issue
3.Enhance performance.
KX400+ Pro 0.19 MB R1.04 2003/10/2 1. Fixed audio will disappear after restarting the OS
KX400+ Pro 0.19 MB R1.04f(Beta) 2003/10/2 Beta Version
KX400+ Pro 0.19 MB R1.05 2003/10/2 1. Support Athlon™ XP 2600+ (FSB 333) CPU
KX400+ Pro 0.19 MB R1.06 2003/10/2 1. Support Barton 3000+ (FSB 333) CPU
KX400+ Pro 0.19 MB R1.06a(Beta) 2003/10/2 Beta Version
KX400+ Pro 0.19 MB R106b(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version)
KX400+Pro-C 0.19 MB R1.00 2003/10/2 Initial Release
KX400+Pro-C 0.19 MB R1.03A( Beta) 2003/10/2 Beta Version
KX400+Pro-C 0.19 MB R1.04 2003/10/2 1. Fixed audio will disappear after restarting the OS
KX400+Pro-C 0.19 MB R1.04f(Beta) 2003/10/2 Beta Version
KX400+Pro-C 0.19 MB R1.05 2003/10/2 1. Support Athlon™ XP 2600+ (FSB 333) CPU
KX400+Pro-C 0.19 MB R1.06 2003/10/2 1. Support Barton 3000+ (FSB 333) CPU
KX400+Pro-C 0.19 MB R1.06a(Beta) 2003/10/2 Beta Version
KX400+Pro-C 0.19 MB R106b(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version)[/code:1]
icbook
уже заработал :)
