By Anonymous (not verified) , 18 February 2006
Как правильно сменить биос на скази контроллере adaptec 29160?
  • No HTML tags allowed.
rgt
20 years 9 months ago
WOLF666 А на сайте производителя по этому поводу ничего не сказано?
сказано,только с английским у меня туго,а понаписано там много чего
rgt
WOLF666 Тогда даже не знаю как Вам помочь
Вот что написано в файле который идет в комплекте с БИОСом. Спрашивайте что именно Вам не ясно. Переводить все мне лениво:
README.TXT File for,
Adaptec SCSI Card 19160 - BIOS 3.10.0
!!! WARNING !!! !!! PLEASE READ !!! !!! WARNING !!!
Do NOT have devices connected to your SCSI Card, when flashing.
DO NOT run this program from a hard disk.
DO NOT run this program from a DOS Window, or a DOS Shell.
DO NOT run this program in 32-bit mode, from NT.
Do NOT run this program with EMM386.exe active.
CAUTION:
This BIOS update is NOT to be used for updating motherboard embedded
SCSI controllers or OEM adapters. Some OEM adapters may have the letter
'S' (designating a 'Special' BIOS version ) when the BIOS is displayed
on the screen, during the systems booting process.
WARNING:
Using this utility for OEM adapters, designed-in controller chips,
or other Adaptec adapters, may render those Adapters UNUSABLE.
Files included with this download:
INSTALL.BAT Batch file for the Installation Procedures.
README.TXT This text file, with addition information.
UPDATE.BAT Batch file for the Flash BIOS Update process.
RESTORE.BAT Batch file for the Flash BIOS Restore Process.
Restores the BACKUP.ROM file to the SCSI host adapter.
xxxxxx.BIN BIOS ROM image to used by Update.bat
FLASH5.EXE Program used to post the xxxxxx.BIN image,
DOS4GW.EXE DOS/4GW Protected mode Run-Time executable,
used by the Flash5.exe program.
FLASH5.DOC Word document, explains switch options for the
Flash5.exe program. The switches can also be viewed
by running " Flash5 /? " at the DOS prompt.
BIOS Download INSTRUCTIONS:
Download the xxxxx.EXE file to an empty Directory.
Run the downloaded xxxx.EXE file. It will self extract/expand.
Copy the expanded files to a bootable DOS floppy diskette.
Boot your system from that, DOS bootable floppy diskette.
Type ' UPDATE ' from the ' A:\> ' DOS prompt,
BIOS Update Instructions:
Copy the expanded files to a bootable floppy.
Boot from the floppy.
Type 'UPDATE' from the ' A:\> ' DOS prompt.
This will run the update.bat file and start your update process.
BIOS Restore Instructions:
Boot the system from your bootable DOS floppy, BIOS diskette.
run 'Restore' from the ' A:\> ' DOS prompt.
This will run the Restore.bat file and load from the Backup.rom file.
Usage Instructions:
The utility will ONLY update ONE controller at a time.
If you have multiple controllers installed, you must remove all
controllers except for the controller which you intend to update.
The very first time you run the utility, the current Bios will be
saved to a file named 'BACKUP.BIN' prior to flashing it with the
newer version.
Any subsequent execution of the utility will ONLY allow restoring
of the previous Bios version from file, without backing up the
current BIOS on the SCSI host adapter.
If you are trying to update several adapters, we recommend using
a different diskette and copy of the utility for each adapter.
