By ROMby Unknown , 25 October 2004
Hello!
I had to patch BIOS of Lucky Start 6LX2 for Celeron 500MHz support becouse of unknown CPU code. I applied cpu ucode suport patch and
Koeffs patch using Patcher. I've uploaded the Bios to board - It hanged on energy Star Logo (no CPU detection and no Memory test) - no Del to enter BIOS settings!!!
I have to use other board to reflash original 9jd8-0a.bin (hot plug BIOS chip
replace method) by uniflasher.
It helped and I used the checkup5 intel utility to update ucode. It loaded it.
The BIOS PAtcher almost kill my mobo BIOS....
  • No HTML tags allowed.
rgt
22 years 1 month ago
Include patcher log in youre message
Anonymous (not verified)
It is nothing to include. All two patches I applied (ucode and Koeffs) finished with success. lha and cbrom version 2.07 got from rom.by (rebuild of bios success). After load it didn't worked - hanged machine. That's all. Uploading software Awdflash 3.31 which was always used by me to upload bin's on this board.
Was boot block updated too?
rgt
Miszka
If you run patcher, report is printed to console and can be redirected to file.
Last two lines like as
(c)2002 apple_rom, www.ROM.by
Read this carefuly!
I don't mean that I can't redirect the stream, but it is nothing special to include I think. I patch using manual switch /m becouse I like to do what I really need / want. You could add \l log_file_name option to command line supporting write to log becouse I had to generate this pressing keys from "memory" like blind man)
Log below
BIOS Patcher ver. 4.51.
Found 1Mbit BIOS!
1. New CPU Support for skip this step press "s" or any another key for continue...
-> fixed.
2. P3-detect error for skip this step press "s" or any another key for continue...s
3. New Koeffs Support >for skip this step press "s" or any another key for continue...
-> fixed.
4. 32Gb-problem not found.
5. Some HDD detect-problem not found.
6. "MB"/"GB" string search is not needed to be fixed.
9. Error display Freq>999MHz not found.
10.Error display Koefs>9.5x not found.
11.New Stepping Support is not needed to be fixed.
12.Tualatin L2-init error not found.
13.New Freq in Setup open not found.
14.Set "Y" as default on exitfor skip this step press "s" or any another key for continue...s
UDMA66/100/133 on UDMA33_only_MB patch not found.
Tweak options addinng
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 27.5%
Adding tweak.tmp 0.0%
Adding start.tmp 87.5%
Adding cpucode.bin 53.6%
(c)2002-2003 apple_rom, www.ROM.by
But why 4.51? it`s for AMD and it`s beta. Try 4.23 it can patch 6LX and 6LX2.
