By NMD , 10 November 2007
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
  • No HTML tags allowed.
KSC5027
Кстати, близок по параметрам:
2SC5353 900/800V 3A TO-220F
_________________
Нет в человеках ничего человеческого...
Приветствую Михаил!
Редкий я на ромбе гость стал-но все же :)
Такой вопрос к достопочтенным ремонтникам БП-Какие ключи ставить в первичку? я в силу дешивезны(1.70грн) ставлю MJE13007-заменяються на многие дорогие транзисторы... например замена кодегеновских С4106-дала более положительный результат, но все таки-это ИМХО, хотелось бы знать точно-каие транзисторы быстрее???
+если меняеться что-то типа транса в БП(конденсатор какой в базовой цепи или с945 во вторичке, да и сами ключи)-часто идет разнос параметров-т.е. ширина импульсов увел/умень-следовательно мошность БП-падает возрастает... был случай уменя-когда при активной(250вт) нагрузке ключи просто умерли-хотя это не самое слабое звено любого БП... что влияет на ширину импульсов?(конкретно в схеме, а не нагрузка и всетакое) Как уменьшить/нивилировать разнос параметров-при любой замене в полумостовой схеме и до нее?
_________________
Что сказали татары прийдя на Русь? "Сдавайтесь русские-нас орда!"
И что им ответили русские?
"А нас-рать!" :) (с)
ivp
19 years ago
2 Arsenal_PC
Несколько раз менял npn во входном каскаде на отечественные полевики - идею заимствовал тут, п.5.1, включал по схеме на рис.12, только транзисторы ставил более мощные (КП-946А), и про стабилитроны не забывал; работают вполне нормально, и стоят копейки - вот еще полсотни штук через Вовку в Воронеже заказал...
_________________
- Ситчик веселенький есть?..
- Приезжайте, обхохочетесь!..
ivp
19 years ago
2 Arsenal_PC
Ну может такое быть, конечно - если почему-то один перестал закрываться к моменту открытия другого...
Или диод, который стоит между коллектором и эмиттером, ушел в обрыв, и транзистор пробило...
А вообще, "зубры" чего-нибудь подскажут, имхо...
_________________
в jnc встречаются TT2144
в fsp встречаются D304X
ктонить может прояснить что это за транзисторы?
_________________
СХЕМЫ БП ATX http://techlabs.nm.ru/
2 Альберт
D304X часто взрываются в ФСП, судя по всему из за низкого качества. В место них 13009 работают долго и счастливо. Хотя по осцилоскопу особой разницы нету.
_________________
http://atxbp.narod.ru/
Что можно поставить во вторичных цепях вместо CEP603AL/CEB603AL
Из за отсутствия нормального осциллографа пока соображений насчет тонкостей нет. Ставил 13007везде, 13009 и BU508A в блоки мощностью более 300. 4106 и т.д из доноров ставил в блоки до 300 ватт. Не поймал зависимость изменения емкости конденсаторов в базовой цепи от случаев взрыва пары силовых. Если позволяло место, в базы ставил полуваттные омлт, возвратов пока с такими резисторами небыло. Темя взрыва силовых в разработке.
BlackCat (not verified)
19 years ago
Что можно поставить во вторичных цепях вместо CEP603AL/CEB603AL :?:
40N03 и выше (с большими цифрами)
