By ROMby Unknown , 16 April 2006
биос от мамы Iwill p55v2 пачу пачером 4.23. Зашивыю AWD FlashWriter 7.8. Но винчестер на 40 гб так больше 8ми и не определяется :(
вот лог
[code:1]
BIOS Patcher ver. 4.23.
Found 1Mbit BIOS!
Enter CPU Name: (max - 32, recomended - 8-24 symbols)
1. New CPU Support : -> fixed.
2. P3-detect error : is not needed to be fixed.
3. New Koeffs Support : -> fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : -> fixed.
6. "MB"/"GB" string search : -> fixed.
7. 65Gb-problem (1-st step) : -> fixed.
8. 65Gb-problem (2-nd step) : -> fixed.
9. Error display Freq>999MHz : is not needed to be fixed.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: -> fixed.
Write Allocate addinng: -> fixed.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 27.3%
Adding start.tmp 87.5%
(c)2002-2003 apple_rom, www.ROM.by[/code:1]
  • No HTML tags allowed.
bigbug
20 years 6 months ago
скорми загрузчику hdx=stroke (где hdx это hda/hdb/hdc/hdd, требуется ядро 2.6) после чего диск будет юзабелен в полном обьёме.
Какая дата/версия биоса используется?
