By Anonymous (not verified) , 12 December 2006
Имя модели : IC35L020AVVN07-0
Дескриптор семейства : VA1O
m-Code : VAUOAF0C
Код версии МП : 6642887D
Страшно шуршит головами, долго висит в бизи.
При проверке служебки жуть, вот лог
ID Start ABA Size Addr(Mem) Length(byte) State
PSHT $0FFE3000 $00A0 $00080000 $0000 RD:-, ID:-
RDMT $0FFE30A0 $0020 $0002C000 $4000 RD:v, ID:v
RLBA $0FFE1093 $0001 $00035600 $00DC RD:v, ID:v
CNSL $0FFE107F $0001 $0003DD46 $00C6 RD:v, ID:-
RWCN $0FFE1080 $0001 $0003D95A $006E RD:-, ID:-
CHNM $0FFE109B $0012 $00037200 $23A4 RD:v, ID:v
SRVP $0FFE1083 $0001 $00039840 $013E RD:v, ID:-
SRVM $0FFE1094 $0007 $00039A40 $0D50 RD:v, ID:v
ZONE $0FFE108F $0003 $0003C480 $0444 RD:-, ID:-
PTRT $0FFE1092 $0001 $00035400 $01E0 RD:v, ID:v
RAM0 $0FFE1002 $0030 $0004C000 $6000 RD:-, ID:-
OVR1 $0FFE1032 $004B $00052000 $1E00 RD:-, ID:-
SMRT $0FFE1087 $0001 $00037040 $00BB RD:v, ID:-
MLBA $0FFE1088 $0001 $0003DCF6 $0026 RD:v, ID:v
SECI $0FFE1089 $0001 $00035B00 $004A RD:v, ID:-
SRIF $0FFE1084 $0001 $0003DD32 $0002 RD:v, ID:v
SERL $0FFE108B $0003 $00036400 $0600 RD:v, ID:v
IDNT $0FFE1081 $0001 $00039600 $0214 RD:v, ID:v
DCOT $0FFE108A $0001 $0003DD1C $000A RD:-, ID:-
PTCH $0FFE107D $0002 $00053E00 $0400 RD:-, ID:-
USAG $0FFE1000 $0002 $000FFFFF $0000 RD:-, ID:-
Holes : 4
ID Start ABA Size RD
##01 $0FFE1082 $0001 -
##02 $0FFE1085 $0002 v
##03 $0FFE108E $0001 v
##04 $0FFE10AD $0053 -
Таблица открытых модулей (RD:-)
Модуль RSVD : Стартовый модуль (RD:-, ID:-)
Модуль ZONE : Таблица зон (RD:v, ID:v)
# Start LBA SPC St.Cyl En.Cyl SPT
0 $00000000 $03D8 $0000 $06D5 $03D8
1 $001A3EE0 $03D3 $06D6 $0D97 $03D3
2 $00340F20 $03C0 $0D98 $144F $03C0
3 $004D39A0 $03C0 $1450 $1C33 $03C0
4 $006AC920 $03A4 $1C34 $2309 $03A4
5 $0083A894 $0399 $230A $29C1 $0399
6 $009BCD5A $0390 $29C2 $306F $0390
7 $00B3921A $037A $3070 $371D $037A
8 $00CAC78C $0373 $371E $3DCB $0373
9 $00E1CAD0 $0360 $3DCC $4537 $0360
10 $00FAD090 $0352 $4538 $4BDB $0352
11 $0110D9C6 $0340 $4BDC $52E3 $0340
12 $0127AD46 $0336 $52E4 $5987 $0336
13 $013CF972 $0326 $5988 $602B $0326
14 $0151DB7E $0318 $602C $6639 $0318
15 $016493B6 $0300 $663A $6D19 $0300
16 $01792DB6 $0300 $6D1A $738B $0300
17 $018C80B6 $02E4 $738C $7A25 $02E4
18 $019F9016 $02D5 $7A26 $80BF $02D5
19 $01B23C8E $02C0 $80C0 $8759 $02C0
20 $01C4614E $02AA $875A $8DE9 $02AA
21 $01D5D79A $0292 $8DEA $9479 $0292
22 $01E6B096 $0280 $947A $9B09 $0280
23 $01F71616 $0270 $9B0A $A199 $0270
24 $02071036 $0260 $A19A $A7D9 $0260
25 $0215E5D6 $0240 $A7DA $AE5F $0240
26 $02248ED6 $022E $AE60 $B4E5 $022E
27 $0232C28E $0220 $B4E6 $BB57 $0220
28 $024072AE $0206 $BB58 $C1E7 $0206
29 $024DB602 $01F3 $C1E8 $C86D $01F3
30 $025A694E $01E0 $C86E $FFFF $01E0
Модуль MLBA : Таблица MLBA (RD:v, ID:v)
MaxLBA : 40188960
Ограничитель MaxLBA : 40188960
Логические параметры :
Цилиндров : 16383
Головок : 16
Секторов : 63
Модуль IDNT : Таблица IDNT (RD:v, ID:v)
Таблица серийного номера (RD:-)
Модуль SRVM : Таблица SRVM (RD:v, ID:v)
Цилиндровые дефекты :
Количество дефектов : 27
Модуль RDMT : Таблица дефектов (G-List) (RD:v, ID:v)
Емкость таблицы : 1899
Количество цепочек : 0
Из них Grown Defects : 0
Модуль DUMP : SRST dump table parameters (RD:v, ID:-)
Указатель на следующий результат : 30583
Общее количество страниц : 30583
Карта страниц :
Заголовок Старт. стр. Страниц Головка Цилиндр К-во сэмплов
wwww 30583 30583 30583 30583 30583
Причем в следующий раз может считать другие модули. NV-RAM, ПЗУ, ц-код отдает. Все совпадает. Убита служебка? Что в этом случае делать?
Вот другой лог
RDMT $0FFE30A0 $0020 $0002C000 $4000 RD:-, ID:-
RLBA $0FFE1093 $0001 $00035600 $00DC RD:v, ID:-
RWCN $0FFE1080 $0001 $0003D95A $006E RD:v, ID:-
SRVM $0FFE1094 $0007 $00039A40 $0D50 RD:v, ID:-
ZONE $0FFE108F $0003 $0003C480 $0444 RD:v, ID:-
PTRT $0FFE1092 $0001 $00035400 $01E0 RD:v, ID:-
MLBA $0FFE1088 $0001 $0003DCF6 $0026 RD:v, ID:-
SRIF $0FFE1084 $0001 $0003DD32 $0002 RD:v, ID:-
SERL $0FFE108B $0003 $00036400 $0600 RD:-, ID:-
IDNT $0FFE1081 $0001 $00039600 $0214 RD:v, ID:-
Holes : 4
##01 $0FFE1082 $0001 v
Добавлено спустя 27 минут 19 секунд:
Забыл сказать, контакты на плате пропаял. Корейца прожарил, и на всякий случай перепаял
  • No HTML tags allowed.
Дык...служебочку ему для начала восстановите полностью...
Alex K
19 years 11 months ago
Пробовал, несколько сервотреков (Main и RSVD помоему) выдают "ошибка восстановления". Я с IBM до этого не работал. Эти сервртреки вручную скрывать надо?
[code:1]Main[/code:1]
Не помню такого модуля...
Пока RSVD не восстановите должным образом, с оставшейся служебкой ничего не выйдет...
Пробуйте брать от какого-нить комплекта и перепишите его...может имеет смысл СА назначить на другую голову...(перекоммутировать)...
Alex K
Так это двадцатка одноголовая
точно...сорри...на модель толком не посмотрел...
Alex K
Восстановление служебной области приводит к этому:
Ошибка очистки сервотрека Cyl: FFE9; Head: 0 (main)
Ошибка очистки сервотрека Cyl: FFEA; Head: 0 (main)
Ошибка очистки сервотрека Cyl: FFEB; Head: 0 (RSVD)
Ошибка очистки сервотрека Cyl: FFEB; Head: 0 (main)
Ошибка очистки сервотрека Cyl: FFF3; Head: 0 (main)
Ошибка очистки сервотрека Cyl: FFF4; Head: 0 (main)
или так:
Ошибка очистки сервотрека Cyl: FFE9; Head: 0 (RSVD)
Ошибка очистки сервотрека Cyl: FFEA; Head: 0 (RSVD)
Ошибка очистки сервотрека Cyl: FFF4; Head: 0 (RSVD)
REM
... да кареец это чудит... жарь, не жарь. тайванец вон сёдня,...прям на руках скончался... а после "сауны" вроде ожил был... но не надолго :(
Alex K
Корейца пересадил, поставил на очистку служебки. Пока на слух ощущений не ощутил, головами шуршит, цилиндры перебирает медленно. Ждемс результата.
Добавлено спустя 1 минуту 46 секунд:
Я имел ввиду изменений не ощутил.
Kuk
2 Alex K
Не всё золото , что блестит.;)
Рекомедация .... пустите кролика на запчасти ... отжил он своё!
Серёзно!
Alex K
Я тоже так думаю. Кореец ни при чем, пересаженый ведет себя так же. Наверное всетаки либо голова, либо блин. Увы. Может кто подкинет схемку и прогу чем перешить le25fv101, программатор дороговато становится. Я платку поюзал еще.
