By ROMby Unknown , 11 December 2006
My PC mainboard: VIA Apollo Pro133A
04/01/2004-694X-686B-6A6LJPRAC-00 (After used bp 6_a10)
I want to hava a BIOS with
1、A good ACPI (always wrong in WinXP/Win2003 ACPI)
2、Can use usb flash disk boot system
3、Can use 160G HDD
Can you tell me what can I do ?
  • No HTML tags allowed.
LKA
19 years 11 months ago
1. No power off? ACPI in bios setup enable before install winXP?
2. I assume, that cannot in any way.
3. Use space accessible bios (example 8G) for install winXP, after install use "diskmgmt.msc".
NiTr0
3) Possible use Disk Manager - s/w that is placed in MBR replacing BIOS HDD routines. Possible trouble - need of re-installing Disk Manager if Windows rewrite MBR during install. I don't know the maximum supported capacity (can it support LBA48 or not), but you may try it.
Anonymous (not verified)
1、Before install WinXp close ACPI,and open APM in WinXp
2、In any way now
3、I used a HPT370A IDE ATA 100 RAID Controller to boot 160G HDD as a SCSI DISK
