By ROMby Unknown , 24 March 2006
Здраствуйте.
у меня матерка DFI CA64TC, VIA Apollo 133T
я пoпробовал пропачит разное прошивки, зашел ее
функция HCLK+33M не явится
тоже нет другое настройки памят
лог :
[code:1]
(c)2002-2003 apple_rom, www.ROM.byBIOS Patcher ver. 4.23.
Found 2Mbit BIOS (6.x)!
Adding +PCI: Remove "otkat" (backup key)
1. New CPU Support : -> fixed.
2. P3-detect error : is not needed to be fixed.
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : -> fixed.
14.Set "Y" as default on exit: not found.
Adding timings-tweak.Adding "Turbo RAM"-tweak.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.15 (C)Award Software 2001 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.15 (C)Award Software 2001 All Rights Reserved.
Adding modul.tmp 41.9%
Adding start.tmp 87.5%
Adding cpucode.bin 55.9%
Warning! BootBlock was changed! Flashing BIOS only WITH BootBlock!
[/code:1]
где проблема ?
поздрави от Булгарий
  • No HTML tags allowed.
ivp
20 years 8 months ago
queer
А какие ключи использовались при запуске патчера?..
Anonymous (not verified)
/p /s /v
DanZer
Попробуйте после патча выставить HCLK-33M ;)
Olmer
- было сделано?
спасибо
