By ROMby Unknown , 6 April 2007
Здравствуйте :-)
Имеется карточка GeForce FX5700 AGP 128Mb. С виду вроде целая, но не работает.
nvflash выдает такую информацию
[code:1]
X:\backup\hardware\video\nv\Winflash5.33>nvflash --display
NVIDIA Firmware Update Utility (Version 5.33)
Adapter: GeForce FX 5700 Ultra (10DE,0341,0000,0000) H:N B:01,AGP,D:00,F:00
The display may go *BLANK* on and off for up to 10 seconds during access to
the EEPROM depending on your display adapter and output device.
Reading adapter firmware image...
Dumping EEPROM image...
0000: 00 00 00 00 4B 37 34 30 30 E9 4C 19 77 CC 56 49 ....K7400.L.w.VI
0010: 44 45 4F 20 0D 00 00 00 3C 01 91 0E 00 00 49 42 DEO ....<.....IB
0020: 4D 20 56 47 41 20 43 6F 6D 70 61 74 00 00 00 00 M VGA Compat....
0030: 01 00 00 00 B0 10 C6 B0 30 33 2F 30 36 2F 30 34 ........03/06/04
0040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0050: E9 24 EE 00 00 00 00 00 7F 40 60 60 00 00 00 00 .$.......@``....
0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0070: EC D0 50 4D 00 00 00 00 00 00 00 00 00 A0 00 B0 ..PM............
0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00A0: 00 00 00 00 00 00 6C 0A 00 00 00 00 00 00 00 00 ......l.........
00B0: 00 00 00 00 A0 19 B6 3B 00 00 00 00 00 00 00 00 .......;........
00C0: 14 02 37 02 00 00 00 00 00 00 00 00 00 00 00 1C ..7.............
00D0: 00 00 00 00 00 00 00 00 57 05 00 6A 00 00 00 00 ........W..j....
00E0: 00 00 00 00 6F 82 6F 36 6F 60 E4 E0 00 00 00 00 ....o.o6o`......
00F0: 00 00 00 00 00 C2 E6 C3 00 00 00 00 AD 00 00 00 ................
X:\backup\hardware\video\nv\Winflash5.33>nvflash --check
Identifying EEPROM...
EEPROM ID (20,EF) : Unknown
ERROR: Supported EEPROM not found
X:\backup\hardware\video\nv\Winflash5.33>nvflash --version
Image Size : 0 bytes
Version : Unavailable (Invalid)
~CRC32 : 00000000
Chip Name : Unknown
Vendor ID : 0000
Device ID : 0000
Subsystem Vendor ID : 0000
Subsystem ID : 0000
Hierarchy ID : None
[/code:1]
Подскажите плз как дальше быть?
Где можно взять прошивку к карточке, и по каким критериям выбрать нужную?
  • No HTML tags allowed.
Попробуйте nvflash, у вас wfflash старая версия. У меня такое было на 6600gt отвал гпу после пропайки все прошилось.
Anonymous (not verified)
18 years 11 months ago
Угу, спасибо за совет, после пропайки ГПУ стало несколько лучше, исчезли глюки с прошивкой, карточка стала включать монитор.
Кстати карточка теперь стала определяться как GeForce FX 5700LE :P
Но... на экране она умеет показывать только разноцветные полосы...
Это на сколько я понял значит что память дохлая?
Память там стоит K4D261638E-TC50...
Может у вас на сайте есть какая-нибудь статейка по взаимозаменяемости микросхем памяти?
Root
вот в Wiki набиваю потихоньку...
Память белые полосы.
VladM
18 years 9 months ago
Цветные полосы лечатся пропайкой(прогревом) процессора, для FX5700 характерная неисправность.
никто вам не даст 100% гарантии что имеено сдохла память. видюха видюхе рознь
