By ROMby Unknown , 16 November 2004
With the help of the forum-member: Master & Moderator Root and a Hexeditor we figured out that the EPA v1 logo has an embedded logo too.
The embedded logo inside the EPA is the small blue Award-Logo which appears in the upper left corner while booting.
I allready asked a Polish friend (which was offline for a long time) to translate:
winamp5.de.tt/borg_bios/epa2bmp/epaopis.txt
winamp5.de.tt/borg_bios/epa2bmp/epaopis2.txt
This is what we figured out:
(With the help of that mentioned epaopis.txt-file)
At the end of an EPA (EPA-format v1 ->without 'AWBM'-header) you can find following 70 bytes (46 Bytes in Hex notation):
[code:1]03 1F 1F 3F 3F 7F 7F 7F 3F 3F 1F 1F 0F 00
80 E0 E0 F0 F0 F8 F8 F8 F0 F0 E0 E0 80 00
00 0E 1D 3D 7B 7B 07 07 0F 0F 1E 18 20 00
00 00 FF FF FF FF FF EF C7 03 03 03 01 00
00 00 E0 E0 E0 C0 C0 C0 80 80 80 00 00 00
END OF EPA-FILE[/code:1]
These bytes result:
a.)following order of Bits:
[code:1] 00000111 10000000 0=transparent/black pixel, 1=colored pixel
00011111 11100000
...and so on[/code:1]
b.)and in conclusion following image
[code:1] 76543210 76543210 76543210 HEX
0 .....XXX X....... 03 80
1 ...XXXXX XXX..... 1F E0
2 ...XXXXX XXX..... 1F E0
3 ..XXXXXX XXXX.... 3F F0
4 ..XXXXXX XXXX.... 3F F0
5 .XXXXXXX XXXXX... 7F F8
6 .XXXXXXX XXXXX... 7F F8
7 .XXXXXXX XXXXX... 7F F8
8 ..XXXXXX XXXX.... 3F F0
9 ..XXXXXX XXXX.... 3F F0
A ...XXXXX XXX..... 1F E0
B ...XXXXX XXX..... 1F E0
C ....XXXX X....... 0F 80
D ........ ........ 00 00
0 ........ ........ ........ 00 00 00
1 ....XXX. ........ ........ 0E 00 00
2 ...XXX.X XXXXXXXX XXX..... 1D FF E0
3 ..XXXX.X XXXXXXXX XXX..... 3D FF E0
4 .XXXX.XX XXXXXXXX XXX..... 7B FF E0
5 .XXXX.XX XXXXXXXX XX...... 7B FF C0
6 .....XXX XXXXXXXX XX...... 07 FF C0
7 .....XXX XXX.XXXX XX...... 07 EF C0
8 ....XXXX XX...XXX X....... 0F C7 80
9 ....XXXX ......XX X....... 0F 03 80
A ...XXXX. ......XX X....... 1E 03 80
B ...XX... ......XX ........ 18 03 00
C ..X..... .......X ........ 20 01 00
D ........ ........ ........ 00 00 00[/code:1]
Today the code has be slightly changed:
[code:1]07 1F 1F 3F 3F 7F 7F 7F 3F 3F 1F 1F 07 00
00 0E 1D 3D 7B FB 07 07 0F 0F 1E 18 20 00
00 FF FF FF FF FF FF EF C7 03 03 03 01 00
00 E0 E0 E0 C0 C0 C0 80 80 80 00 00 00 00[/code:1]
Here you can see the images of the embedded blue small Award Logo.
http://www.winamp5.de.tt/images/bioslogos/award-logo--robert-orlinski.png
larger view:
http://www.winamp5.de.tt/images/bioslogos/award-logo--robert-orlinski-8x.png
http://www.winamp5.de.tt/images/bioslogos/award-logo--robert-orlinski-8xa.png
More results will be added soon if the Polish friend has translated the docs.
In future ABR G2 ( http://bnobtc.pix-art.com/abr-2 or http://biosgfx.narod.ru ) will support to modify this embedded logo too.
- I hope so. :)
  • No HTML tags allowed.
Root
21 years 11 months ago
Перевод на русский (by Root):
С помощью участника форума Root'а и hexeditor'а, мы обнаружили, что логотип EPA v1 также содержит встроенное лого.
Этот встроенный логотип внутри EPA - маленький синий логотипчик Award, появляющийся с левом верхнем углу экрана во время загрузки компьютера.
Я уже попросил польского друга (который был долгое время в оффлайне) перевести:
http://winamp5.de.tt/borg_bios/epa2bmp/epaopis.txt
http://winamp5.de.tt/borg_bios/epa2bmp/epaopis2.txt
Наши открытия:
(с помошью упомянутого файла eaopis.txt)
В конце EPA (формат v1 -> без заголовка "AWBM") можно обнаружить следующие 70 байтов (46h):
00 00 E0 E0 E0 C0 C0 C0 80 80 80 00 00 00[/code:1]
Эти байты дают:
а) следующий порядок битов:
[code:1]00000111 10000000 0=черный/прозрачный пиксел, 1=цветной пиксел
00011111 11100000 на каждый пиксел отводится по 1 биту
и т.д.[/code:1]
б) в качестве результата следующую картинку:
В настоящее время, код немножко изменен:
Здесь Вы можете видеть изображения маленького синего Авардовского логотипа:
с увеличением:
Позже будут добавлена новая информация, если польский друг переведет доки.
В будущем ABR G2 ( http://www.winamp5.de.tt/borg_bios/abrg2 или http://biosgfx.narod.ru ) будет иметь возможность редактирования встроенного лого тоже, я надеюсь.
PS: сорри, если немного криво перевел :lol:
ivp
Borg Number One
Root
Все замечательно, только к проблемам патчера это какое имеет отношение?..
Перемещаю в ветку Аварда...
Дык мы все это знали с момента ковыряния обычного. Вот тот факт, что байтиков 5, а не 6 стоил мне часа времени штоб понять, почему не лэзэ :)
