By Anonymous (not verified) , 10 November 2006
Трабла в следующем:
Нужно поставить камешек FC-PGA
На сайте делла написано что мама их держит,
Биос обновлен до A10
Пробывал 4 копера (П3 и селеры) - Не стартует.
Думаеться мне, что проблема в биосе, тк в апдейтах пишут:
BIOS Release Notes
Systems: OptiPlex GX100
Version: A10
Release Date: 08-30-2001
1. ESCD is cleared when asset tag PASS:xx/xx changes.
2. Added ability to turn the USB controller on and off in setup.
3. Updated selectable boot capability. When a device is removed
its place in the boot list is saved in case it is ever readded.
4. Updated some CPU microcodes.
5. Added BBS calling interface to SMBIOS.
6. During NVRAM updates the reset and power buttons are now disabled.
7. Added support for 48-bit LBA disk drives.
8. System now beeps when CTRL-ALT-F10, or F12 is pressed
9. Fixed a few potential Plug & Play configuration errors.
10. Added a fix to allow certain cards (PERC/3) to work properly.
11. IRQ 12 is now reserved.
Dimension Jxxxc
Version: A09
Release Date: 4-25-2001
1. Updated the Coppermine B0 microcode from patch level 10 to 14.
2. Added the Coppermine D0 68Ah microcode for skt370.
3. Changed copyright date to 2001
Dimension Jxxxc
Version: A07
Release Date: 9-18-2000
1. Put 8 loads DIMM configurations back to 2x, fixed 12 loads to be 2x.
2. Display 866 for 867 processors (Processor speed).
Dimension Jxxxc
Version: A06
Release Date: 7-28-2000
1. Added Celeron C0 stepping microcode update, patch level 08
CPU ID: 686, 633 and 700 MHz.
2. Added function 41 and 48 to legacy floppies for MS Easy
PC requirement.
Dimension Jxxxc
Version: A05
Release Date: 6-26-2000
1. Correct ACPI handling of PME events, to work better with Windows 2000.
2. Allow chassis intrusion "status" to return current state through SMBIOS.
3. Properly report onboard sound devices in SMBIOS.
4. Fix performance problem with Promise IDE RAID Card,
5. Modified the SDRAM memory buffer strength to support mixed DIMMs.
Tuned values for specific memory configurations.
6. Change flash program to check system type beofre asking for password.
7. INT19 handler now calls option ROM's INT18 handler if all
boot devices fail.
8. Fix memory reporting through Int 15, Function 88.
9. Remove IRQ6 from PCI IRQ availability list.
10. Add ability in BIOS SETUP to adjust PCI IRQ settings.
11. Added support for newer CPU's.
12. Fix incorrect POST error with removable media hard disks.
13. Added support in BIOS SETUP for IRQ reservations.
14. Fixed backspace key in password entry in system setup.
15. Added SMBIOS tokens for ACPI enable/disable and PXE_NEXT_BOOT.
Dimension Jxxxc
Version: A04
Release Date: 1-28-2000
1. Correctly set power-on-reason-code in all conditions.
2. Adjust ACPI code for better Windows 2000 support.
3. Change POST code to prevent possible RTC startup problem.
4. Update SMBIOS CPU structure for all supported processors.
5. Add new Microcode for newer supported processors.
6. Add code to prevent mouse driver causing false wakes from standby.
7. Updated processor speed support for all supported processors.
Может машина не работает с кампями проданными не Деллом?
Или в чем загвозка?[/quote]
  • No HTML tags allowed.
Проверить, поддерживает ли копперы плата, а не биос.
Посмотрю тока вечером.
У меня была подобная тачка - Dell Optiplex GX1 так там в маркетинговых целях Dell в последних версиях прошивок BIOS специально вырубила поддержку "новых" процов - нужно было откатится на прошивку A07 (кажись) да и копперы далеко не через все переходники заводились (вроде как только Slocket-III 100% гарантировал работу копперов с прошивкой А07). Поищи информацию на форумах поддержки Dell - там куча всего была, да и так через Google я много чего находил.
Как проверить? :oops:
