By icbook , 29 October 2006
Всем, кому интересно, сообщаю, что есть такая версия:
[code:1] AWDFLASH v8.73 (08/03) (C)Phoenix Technologies Ltd. 2006 All Rights Reserved
Usage: AWDFLASH [FileName1] [FileName2] [/[/...]]
FileName1 : New BIOS Name For Flash Programming
FileName2 : BIOS File For Backing-up the Original BIOS
?: Show Help Messages
py: Program Flash Memory pn: No Flash Programming
sy: Backup Original BIOS To Disk File sn: No Original BIOS Backup
Sb: Skip BootBlock programming Wb: Always Programming BootBlock
cd: Clear DMI Data After Programming cc: Clear CMOS Data After Programming
cp: Clear PnP(ESCD) Data After Programming
LD: Destroy CMOS Checksum And No System Halt For First Reboot
After Programming Tiny: Occupy lesser memory
QI: Qualify flash part number with source file
E: Return to DOS After Programming R: RESET System After Programming
F: Use Flash Routines in Original BIOS For Flash Programming
cks: Show update Binfile checksum cksXXXX: Compare Binfile CheckSum with XXXX
vgaXX: Change to VGA mode XX(Hex value). ch: Update HOLE.
Hx: Only update the specified Hole(0~7).
NVMAC:XXXXXXXXXXXX NVGUID:XXXXXXXXXXXXXX
Support nForce Input MAC,GUID Function,with "/wb" to update MAC and GUID.
Example: AWDFLASH 6A69R000.bin /py/sn/nvmac:xxxxxxxxxxxx/wb[/code:1]
  • No HTML tags allowed.
