не могу приаттачить файл к мессаге
Создал тему:
rom.by/forum/Hyundai_Q94D_prikidyvaetsja_mertvym_lechitsja_pereshivoj
сабж. Виндовая опера, Версия: 11.10, Сборка: 2092
При нажатии "прикрепить" получаю:
An HTTP error 0 occurred.
/upload/js
После нажатия "ок" вижу:
{ "status": true, "data": "\x3cdiv class=\"messages status\"\x3e\nFor security reasons, your upload has been renamed to \x3cem\x3eQ94D_Ok.bin_.7zip\x3c/em\x3e.\x3c/div\x3e\n\x3ctable id=\"upload-attachments\" class=\"sticky-enabled\"\x3e\n \x3cthead\x3e\x3ctr\x3e\x3cth\x3e\x3c/th\x3e\x3cth\x3eУдалить\x3c/th\x3e\x3cth\x3eСписок\x3c/th\x3e\x3cth\x3eОписание\x3c/th\x3e\x3cth\x3eВес\x3c/th\x3e\x3cth\x3eРазмер\x3c/th\x3e \x3c/tr\x3e\x3c/thead\x3e\n\x3ctbody\x3e\n \x3ctr class=\"draggable odd\"\x3e\x3ctd\x3e\x3c/td\x3e\x3ctd\x3e\x3cdiv class=\"form-item\" id=\"edit-files-12959-remove-wrapper\"\x3e\n \x3cinput type=\"checkbox\" name=\"files[12959][remove]\" id=\"edit-files-12959-remove\" value=\"1\" class=\"form-checkbox\" /\x3e\n\x3c/div\x3e\n\x3c/td\x3e\x3ctd\x3e\x3cdiv class=\"form-item\" id=\"edit-files-12959-list-wrapper\"\x3e\n \x3cinput type=\"checkbox\" name=\"files[12959]
    \" id=\"edit-files-12959-list\" value=\"1\" checked=\"checked\" class=\"form-checkbox\" /\x3e\n\x3c/div\x3e\n\x3c/td\x3e\x3ctd\x3e\x3cdiv class=\"form-item\" id=\"edit-files-12959-description-wrapper\"\x3e\n \x3cinput type=\"text\" maxlength=\"256\" name=\"files[12959][description]\" id=\"edit-files-12959-description\" size=\"60\" value=\"Q94D_Ok.bin_.7zip\" class=\"form-text\" /\x3e\n \x3cdiv class=\"description\"\x3e\x3csmall\x3ehttp://www.rom.by/files/Q94D_Ok.bin__0.7zip\x3c/small\x3e\x3c/div\x3e\n\x3c/div\x3e\n\x3c/td\x3e\x3ctd\x3e\x3cdiv class=\"form-item\" id=\"edit-files-12959-weight-wrapper\"\x3e\n \x3cselect name=\"files[12959][weight]\" class=\"form-select upload-weight\" id=\"edit-files-12959-weight\" \x3e\x3coption value=\"-1\"\x3e-1\x3c/option\x3e\x3coption value=\"0\" selected=\"selected\"\x3e0\x3c/option\x3e\x3coption value=\"1\"\x3e1\x3c/option\x3e\x3c/select\x3e\n\x3c/div\x3e\n\x3c/td\x3e\x3ctd\x3e22.26 кб \x3c/td\x3e \x3c/tr\x3e\n\x3c/tbody\x3e\n\x3c/table\x3e\n\x3cdiv class=\"form-item\" id=\"edit-upload-wrapper\"\x3e\n \x3clabel for=\"edit-upload\"\x3eПрикрепить новый файл: \x3c/label\x3e\n \x3cinput type=\"file\" name=\"files[upload]\" class=\"form-file\" id=\"edit-upload\" size=\"40\" /\x3e\n\n \x3cdiv class=\"description\"\x3eImages are larger than \x3cem\x3e800x600\x3c/em\x3e will be resized. The maximum upload size is \x3cem\x3e2 Мб \x3c/em\x3e. Only files with the following extensions may be uploaded: \x3cem\x3ejpg jpeg gif png txt doc xls pdf ppt pps odt ods odp php3 rar zip 7zip\x3c/em\x3e. \x3c/div\x3e\n\x3c/div\x3e\n\x3cinput type=\"submit\" name=\"attach\" id=\"edit-attach\" value=\"Прикрепить\" class=\"form-submit\" /\x3e\n" }
И приаттачить не дает и тескт мессаги не сохраняется:(
Используйте Mozilla Firefox. Когда-то раз получилось с Оперой, но уже не помню какие установки делал.
